Rim backspacing to offset
  • Digitalwave
    is a poseur
    • 6299
    If a staggered set of rims has 4.5" and 5.5" of backspacing, how do you turn that measurement into offset?
    RISING EDGE
  • E30SPDFRK
    • 5714
    What is the width of the wheels?
    Byron
    Leichtbau
    • Digitalwave
      is a poseur
      • 6299
      7" and 8".
      RISING EDGE
      • E30SPDFRK
        • 5714
        Backspacing is the distance from the mounting surface to the backside lip of the wheel. Offset is the amount the mounting surface is away from the center line. Is the 4.5 backspacing on the 7 or 8 inch wheel?
        Byron
        Leichtbau
        • xLibelle
          • Aug 2004
          • 2673
          wtf man... an OG like yourself should know theres a forum for this kind of thing... and the question has been answered time and time again... you ok tj???
          ...divide rim width in half, subtract the 4.5 and 5.5 measurements from that and convert to metric.
          • Erick
            Official R3V Drifter
            • 11169
            1" = 25.4mm
            A 7" wheel = 177.8mm so from the inner lip of the wheel to ET0 would be at 88.9mm
            Now, 4.5" = 114.3mm. Removing that from the center (114.3-88.9), you're left with 25.4mm of positive offset. (Nice coincidence)
            Following the same math, that 8" wheel should have an offset of +38.1mm
            If that makes any sense.
            So the answer is no TJ, they are not worth buying :p
            ..::Support FullOpp::..
            FullOpp Stickers for sale!
            Feedback Thread
            • fretburnr
              • Jan 2005
              • 1496
              offset is backspacing minus (1/2 wheel width lip to lip). Then convert from inches to mm.
              Erick, keep in mind that wheel width is measured from bead to bead, so add maybe 1/2" for lip-to-lip measurement, depending on the wheel. It's best to accurately measure.
              for example, if that 8" wheel (we'll call it 8.5" lip to lip) has a 5.5 backspacing,
              5.5 - (0.5 * 8.5) = 5.5 - 4.25 = 1.25". 1.25" is 31.75mm.
              Jay
              • Erick
                • 11169
                well I'm considering the seller that measured them did the right measuring. But who knows how to do that nowadays.
                Perhaps it was a bad call on my side. :p
                Oh, and stop browsing around for other 16" wheels and drop some sort of deposit on the Ewings already :p
                Feedback Thread
                • fretburnr
                  • Jan 2005
                  • 1496
                  no biggie. for most customers, they want to know bead-width not lip-width, as they need to know what size tire to purchase.
                  Jay
