Do I really need to change my timing belt
  • Dave
    E30 RAT
    • 11675
    Pull the radiator and just change the pump. If you give yourself the extra room (not much extra work to do it) it can be done fairly easily. Leave the belt in place.
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • ///M42 sport
      • 3952
      like nando said, don't need to touch tensioner when replacing waterpump. The tensioner is already bolted down and won't move when removing the waterpump, therefore tension is maintained on the belt. If anything, the spring that attaches to the tensioner makes putting the waterpump back in a pain in the ass.
        • 34847
        that's why you leave it out :p
        • XXX
          • Jan 2008
          • 88
          yes
          • blunttech
            • 12850
            Originally posted by XXX
            yes
            hi
            sales@blunttech.com
            www.blunttech.com
            Like us on Facebook
            • Erick
              Official R3V Drifter
              • 11169
              Listen to nando, he has over 9000 posts. :D
              j/k. Seriously though... I agree with nando.
              ..::Support FullOpp::..
              FullOpp Stickers for sale!
              Feedback Thread
              • StereoInstaller1
                GAS
                • 22679
                Nando, I only joking.
                Closing SOON!
                Thanks for 10 years of fun!
                  • 34847
                  lol no prob
                    • 34847
                    shit.. when did that happen? I'd say I have no life, but I post mostly from work :p
                    • Erick
                      • 11169
                      Ditto. :p
                      Feedback Thread
                      • kommissar
                        • Dec 2005
                        • 402
                        Originally posted by nando
                        you guys are idiots :p
                        if he just changed it and it only has 2000 miles, he doesn't need to do it again just to do the waterpump. not neccesary at all. You don't have to loosen the tension on the belt at all - you can remove the waterpump separately without touching the belt. just make sure the tensioner is tightened down really well. you don't really need the tensioner spring for anything but the initial installation of the belt. once the tensioner is tight it's just dead weight.
                        Nando is right, you don't need to take tension off the belt to change the pump, as the spring is used only for the initial installation of the timing belt. You can change the pump without changing the belt.
                        • chrisesteschiro
                          • 361
                          Thanks guys......I didn't have my bentley handy....so off to work I go....
                          • mikeedler
                            • 6707
                            At BMW they will tell you also- atleast at my work, you dont need to change it either. You can take it off, but if you do, just put it on in the same direction it came off(so the belt runs the same way). They actually make tools to check and retension timing belts, so ignore the kiddies.
