I am planning to change a timing belt soon and water pump and i was wondering what other parts should i replace while im doing it? a list of parts would be greatly appreciated, thanks in advance.
Timing belt
If they aren't leaking I would leave them alone though. Check into a cap, rotor, rad hoses and v belts.:: PNW Crew ::
'87 325 4dr, '74 2002Comment
1990 E30 325ic (sold for more than I paid for it after 5 Years)
1995 E30 325e (in progress)
1987 E30 325is (totaled)
1990 E30 325i
1991 E30 318is M50 PWR
1996 E36 328ic
1997 Z3
2006 F150 Super Crew 5.4L 6.5' bed The work horse (need something to drag all these old BMW's home for resurrection.)Comment
so heres my list so far:
Timing belt
tensioner
water pump
water pump gasket
water pump bolts
pulleys
other belts
cam seal
intermediate shaft seal
crank seal
o-ring on cam shaft retainer
cap and rotor
thermostat
Ii would rather do it all in one swoop so anything else is that area that I should replace?sigpicComment
The front main crank seal is not something easy to change BTW.:: PNW Crew ::
Yeah, unless you have leaks I'd just stick with the belt and pump and such.
Where in MA are you?'89 325is S50 Track Montser
'04 X5 Daily/Tow Vehicle
http://www.avarestoration.com
http://www.myspace.com/brendanfiddle
Click here if you want to be my zombie slave...
http://www.youtube.com/user/Fidhle007
I just got done doing mine today actually. I def. replace all belts if need be as well as coolant hoses since they got to come out anyway. Water pump also and do make sure that you get every part of the old water pump gasket off the engine block too or you will have to go through the whole procedure again which is a pain but easier the second time through. lol other things you will need as well would be a 3mm allen wrench (for the rotor), 32mm open ended wrench(for the fan) and a 22mm socket. another thign i would recommend is to make sure you empty all the fluid out of the engine or atleast have soemthign to catch all the coolant that will coem out.Comment
