Spring Pad Question
    Spring Pad Question
    I want my front end lower. Is it worth the trouble to remove my front sprig pads? Thanks
    it won't make much more than 1/4" to 3/8" worth of difference. it depends on if you have the means to do it easily.
      Any problems associated with removing them?
        There will be metal on metal contact. That is the only problem I could see with it. The spring is probably compressed on there to the point where it wouldnt be moving around.
        Aaron
          No issues, just some rub wear and rust on the springs. Oh and some squeak.
            Thanks guys, I might do lowering spring seats from BMP soon, I'm just not happy with the stance.
              who had those and werent happy with them?
                ive heard nothing but bad things. ive considered getting them, but thats as far as i went before gettign shot down by everyone .
                  Do you have camber plates too?
                  p.s. check your PM
                  90 325is
                  IE stage 3s and refeshed m20....
