My V8 E30s Battery wont hold charge?? Its new...
    Hi guys im having a bit of an issue with my e30 v8, the battery wont hold its charge for longer than a week,
    now the alternator is working fine as ive just had that tested, also the battery is fine as thats brand new and its a 660cca and its been tested as well.
    An auto electrical guy has suggested it might well be a draining power somewhere
    Where are the usual power leaks in e30s?
    Any help would be great
    Riley
    sigpic340hp V8 e30 FINISHED!!!!!
    Quick vid for ya ;) http://www.youtube.com/watch?v=vp5Eaf8xOgM
    NEW One on the track :)
    http://www.youtube.com/watch?v=K-AX5SzSLnk
    Cleaning up some 911s and Jap turbos
    http://www.youtube.com/watch?v=Ad79wsLdle4
    1) make sure the car is off.
    2) wait 5 minutes
    3) goto your battery and measure the amperage, i believe, across it. (from B+ to b-)
    4) start pulling fuses one by one until the amperage drops significantly
    5) trace the circuit on the last fuse you pulled (say the radio) and check all connections or that area to see what is staying on.
      Aftermarket stereo or other non-BMW wiring? That's about 80% likely to be your culprit.
        grounds, grounds grounds-- make sure you have good grounds to the engine, alt and battery.
          You cant measure amperage in parallel with the battery, you need to measure in series with one of the battery cables.
          James Peacock
          WWFSMD?
            Sweet ill check those out tonight and get back you you all
              Bingo +1
                check your hazard switch
                  Common places in the normal e30 are worn door and trunk light switches, head units, and bad grounds. Because of your engine swap, it could be a wide variety of stuff, so the pulling fuses method is probably your best bet.
                  Project M42 Turbo
                    i say engine ground
                    Build Threads:
                      Had same issue on a stock eta with high milage. I took all the terminals apart(engine bay power) etc... and gave them a good cleaning and hooked it back up. Fixed my issue. Cleaned the ground and power cable on the battery as well.
                        Cheers will look into those as well
                          I think im Having a Grounds problem as well. My lights flicker a little and i have a swap. How can i fix this ?
                          M52 |S52 Cams|E36 Rack Swap|GC Coilover Kit |. . . . . . . . . More To Come
                            Ive still got to fix mine
                              easiest way in the past for me to find culprits like this is with a test light and just run through all the fuses and relays to see what has power when it shouldnt. Saves pulling and/or measuring stuff.
                              Just a little project im working on
                              - http://www.lse30.com -
