physics question
  • akorcovelos
    • Dec 2006
    • 1149
    physics question
    posted this on E30tech also, lets see if we get the same solution!
    ok, lets see who can solve this.
    knowns are distance of fall (2') force of impact (500 lbs).
    I need to know the mass of the falling object to generate the 500 lb impact force when dropped from 2'.
    edit: please show your work!
    2012 MCSCC/NSSCC CP class champ
    HSAX Instructor
  • mrsleeve
    • Mar 2005
    • 16390
    force = mass x acceleration, acceleration is a constant at 9.8m per second^2
    for give me if that dosent help its been a long time since physics.
    Originally posted by Fusion
    William Pitt-
    • akorcovelos
      • Dec 2006
      • 1149
      Right, I'm having trouble solving for m with the knowns being a=9.8m per s^2 and F=500 lbs
      HSAX Instructor
      • uofom3
        • Jan 2004
        • 5392
        500 = m * 9.8mps^2
        m = (500)/ (9.8mps^2)
        that seemed really easy... maybe I'm missing something
        PNW Crew
        90 m3
        06 m5
        • bwanac
          • 3354
          since we are doing it in english units or whatever its called, g = 32.2 ft per sec^2
          • akorcovelos
            • Dec 2006
            • 1149
            right, I should stop mixing the units like that , it can be confusing.
            HSAX Instructor
            • bwanac
              • 3354
              is that what you wanted? because it seems you need to know how long the impact is to understand the force.
              • fretburnr
                • Jan 2005
                • 1496
                if you use F=ma,
                500 lbf (pounds force) = 2,224.111 Newtons
                2,224.111 = m * 9.8 m/s^2
                2,224.111 / 9.8 = m
                226.95 = m
                226.95 kg ~= 500 lb. duh, that's what we started with.
                you need to look at it as a momentum based collision. i'll be back in 5, gotta meeting at work.
                Jay
                • StereoInstaller1
                  GAS
                  • 22679
                  6 replies and no treadmill?
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • uofom3
                    • Jan 2004
                    • 5392
                    r3v has recently made a turn for the sane/helpful. It's pretty strange...
                    PNW Crew
                    90 m3
                    06 m5
                    • bwanac
                      • 3354
                      Originally posted by fretburnr
                      if you use F=ma,
                      2,224.111 / 9.8 = m
                      226.95 = m
                      yup. P=mv and F=ma where a=dv/dt.
                      • fretburnr
                        • Jan 2005
                        • 1496
                        scratch that, it's not momentum. I just worked it out and it comes out the same, then BLAO! lightbulb, and memory from physics class.
                        Pounds isn't a measure of mass, it is a measure of force at normal G acceleration.
                        500lb impact requires a 500lb object. I just proved it with math in the prev. post.
                        Jay
                        • fretburnr
                          • Jan 2005
                          • 1496
                          further proof:
                          f= m * (dv/dt)
                          v^2 = Vo^2 + 2 a (x-Xo)
                          v^2 = 0 + (2 * 9.8 * 0.6096m)
                          v^2 = 11.948
                          v = 3.457
                          v = Vo + a t
                          3.457 = 0 + 9.8 t
                          .0353 = t
                          F = m * (3.457 / .0353)
                          2224.111 N = m * 97.93
                          226.94 kg = m
                          226.94 kg ~= 500lb
                          Jay
                          • akorcovelos
                            • Dec 2006
                            • 1149
                            So your telling me that I need to drop a 500 lb weight from 2' to generate 500 lbs of impact on an object? Gravity wouldn't increase the force?
                            HSAX Instructor
                            • LivingLegend06
                              • Dec 2006
                              • 1604
                              lol guys, you all suck at physics.
                              The object does not simply create a force on impact, it needs to come to rest over some distance over which it will have an acceleration.
                              If this is some kind of homework problem its a trick question and just say that the object has a mass of (500/32.2) slugs.
