^^ Exactly. Everyone else is just wrong.
FretBurnr: You were the closest with the momentum. But what we are actually looking for is the change in momentum from the instant of impact until it actually reaches rest. This is a highly complex situation, and is worlds ahead of newton's second law (Net force = m*a). That only works in classical physics, which can only deal with relatively large objects. Newton's second is no good when we look at the molecular level. You will need quantum mechanics to completely understand that.
In this situation, whatever surface you drop it on will bend upon impact, and it will take a very small amount of time to make the object come to rest. You need a function for the force with respect to time. Then and only then can you solve this problem. And if you were to have this function, you can find that P(final)-P(initial) = The integral of F(t)dt from t=0 (initial impact) to t final (object at rest). This is called impulse, and it's what you're looking for.
Bingo. Like I said on the other side, you are asking a problem that you can't get an answer to with the data provided.
