ix wheels
  • rede30
    • 4697
    ix wheels
    for putting e30 ix wheels on a 325i what spacers, if any, are needed. thanks
    D
  • iXer
    • 242
    You should add a spacer that brings you down to ET 30 mm or lower, if you're talking about stock iX wheels you need a thick spacer because they have ET 47 mm or something, don't remember the exact number. It varies a little, an example I heard about was someone who ran ET35 wheels on his 325i and had to use a 10 mm spacer to clear the struts in the front, in the back it's less critical.
      • 34835
      stock ix wheels are ET41. unless you get them dirt cheap, I'd get something else. you're going to spend $200 on spacers, when you can fit Ronal LS on your car for ~$600 (still on sale I think) which are wider and sit close to the fender and have waaay more lip. I went with euro weaves on my ix because of the differences in offset, spoke shape and lip depth (although the lip isn't exactly huge on euro weaves either).
      • e30evolution
        West Werks
        • 1888
        you SAI will be off now with the incorrect offset.... not too big of a deal, but .....
        caster change on turning will be altered as well as camber.... your tires will have more of a load on the inside while turning and the outside of the tire will scrub...... causing the tires to feather....
        most likley you wont have a problem with it tho
        http://www.westwerksauto.com
        • iXer
          • 242
          I don't see what you mean.
            • 34835
            yeah.. I don't think running an ET24 rim on the ix is going to hurt any more than running an ET20 wheel on any other E30. Actually I had ET20 16x7.5" wheels on my ix when I first got it. :)
