bent oil cooler
  • bimmer8604
    • 3017
    your oil cooler isnt really going to effect your operating temperatures that much. i highly doubt you have a problem. stop thinking that because you have an oil cooler the car is going to really run cooler.
    No leak, no fix. Why try to fix something that aint broken?
    1988 M3, 97 840, 99 XJ
    DILLIGAF
    • einstein57
      • Jun 2007
      • 10780
      Very true under normal operating conditions. ETAs work fine w/o them.
      www.gecoils.com
      • DaveSmed
        • Apr 2007
        • 1407
        Yea, your 20 year old 170hp engine really never needed one to begin with, hell new Corvettes don't even have them.
        -Dave
        2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
        Need some help figuring out the ETM?
        • eshghehBMW
          • 162
          Ya, I've realized that this might not be the a problem but regardless I will straiten it and paint it white.
          Thanks for this DIY btw...
          Originally posted by einstein57
          My DIY thread
          Also have the 88+ core laying around.
          • DaveSmed
            • Apr 2007
            • 1407
            Good plan, it going behind a white lip? Post up a pic, I painted mine black because I thought white would just make it look like bad overspray from the lip.
            -Dave
            • einstein57
              • Jun 2007
              • 10780
              White will get dingy quick. Go silver. It will make it look like an aftermarket update. And don't corvettes have aluminum blocks which would dissipate heat a lot better than an iron block thus eliminating the need for a supplemental cooler?
              www.gecoils.com
              • ethree
                • Aug 2007
                • 1216
                Yes, and massive amounts of r&d regarding airflow and the engine compartment.
                • DaveSmed
                  • Apr 2007
                  • 1407
                  Biggest thing with the Corvette was the tradeoff between installing an oil cooler which adds weight, complexity, possible leak points, cost, etc. vs. how many customers would actually benefit from its inclusion. Solution? Factory fill of Mobil 1 synthetic. That way the customers that do track their car will be OK should oil temps climb above 300 deg, and the vast majority will benefit from the omission of the oil cooler's downsides.
                  Corvettes with the "Track-Pack" option DO have the oil cooler added.
                  -Dave
