Water Pump and Timing Belt Life Question
  • jonmacs22
    • Jun 2004
    • 17
    What is the maintenance life of these two parts? Thanks.
    Jon
  • Alex Mc
    • 281
    The factory interval is 60,000 miles for the timing belt, at which point the water pump should also be replaced, however, we've never recommended that sort of length. Finding a car with 50k (or less) on her timing belt thats broken is not uncommon.
    We recommend replacing at 45,000 miles, which is sooner, yes, but necessary if you want to ensure a strong link with cam gear. Always replace the water pump with the timing belt. The timing belt tensioner actually uses the water pump as loaded surface, so to remove the water pump is to remove the belt. And if you're doing a belt you might as well do a water pump :)
    Current: Brilliantrot '91 318is M20B25
    Former: '88 M3 3.2L, '91 318is 2.0L, '90 318i, '85 325e 2.8L, '84 318i 2.0L, '84 318i, '90 325is
    wamchenry@gmail.com
    insta: @simple_machines
    • DarkWing6
      • Apr 2004
      • 7144
      What does it usually cost to have a shop do this and what do just the parts cost?
      • Jand3rson
        • 37587
        It's not even worth it to have a shop do it. Changing the water pump and timing belt is seriously SOOOOO easy. :up:
        • ///M42 sport
          • 3952
          can you do a simple write up? I need to do this soon.
          to have a shop do this costs $400-600.
          ________
          Avandia lawsuit information
          • Jordan
            • 12916
            The parts cost less then $100 total.
            Buy a Bentley manual.
            https://mtechniqueabs.com/
            • ///M42 sport
              • 3952
              where's a good place to get parts? I was thinking bimmerparts.com
              ________
              Airsoft Shotguns
              • DarkWing6
                • Apr 2004
                • 7144
                I was just curious because the guy I am buying the car from just had this done, and I can tell him that I'd just do it myself. Thanks guys. I hope I get this freakin' car.
