4x100 to 5x?? wheel adaptors
  • my325i
    • Apr 2008
    • 81
    Anyone running the 4 lug to 5 lug spacer/adaptors? And what do you think?
  • Jparkr
    HR Admin
    • Jan 2006
    • 3494
    I'm gonna be nice because I know what is about to happen.
    They are stupid; and no. No one here will be running them.
    1987 PRO-3 car /1990 325is (2.7i Concours)
    • devonjordan
      • Jul 2006
      • 2386
      i think there is one person here running them. but i agree they are stupid...
      Hemingway said it best. “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
      Help a brother out, buy your detailing products here...
      • Wishno87
        • 6025
        isint E30Trash running them? hes got really high offset wheels to compensate though
        • M42Technik
          • 9781
          Elliott is running custom made spacers, and the wheels he started with had a very high offset to compensate for the large adapters like ^ he said.
          Quality adapters are expensive and can run from $250-400 depending on what you are trying to fit. Then you have to worry if the wheels will fit with adapters.
          They are not stupid when you have a quality part that does the job correctly. People think they are unsafe but there are hundreds of cars (mainly VW guys) who run these with no problems.
          Its mainly the question of if the wheel will fit with the adapters in place, since most wheels don't have high enough offsets to compensate for adapters.
          Reminiscing...
          • george graves
            • 19995
            ^what he said.
            They are not "stupid" or "unsafe" if made right. But they sure are a bit weird.
            The thing with "X lug to Y lug" adapters is that they HAVE to be thick for the adapter to bolt to the hub. I looked into it once and I think I was quoted a min thickness of close to 25mm (~1").
            Originally posted by Matt-B
            • M42Technik
              • 9781
              I also looked into it and the minimum was 35mm.
              Reminiscing...
              • cramer
                • 1812
                H&R adapters are TUV rated, perfectly safe for road use.
                Chris
                90 Corrado/91 M3/01 M5
                • Tree18is
                  • Mar 2004
                  • 2703
                  EVERYONE but us uses them with no poblems. be we have bmw's so there way to fancy for them.
                  • M42Technik
                    • 9781
                    Your avatar reflects your spelling quite nicely.
                    Reminiscing...
                    • Van Westervelt
                      • 9365
                      Spacers and adapters are all prefectly fine, so long as you use high quality materials, and you do it right.
                      With adapters, idealy, you want to find a set that has steel sleeves inserted where the wheel bolts to the adapter. As opposed to just bare aluminum, which will just weaken and break.
                      • Mossman
                        • Apr 2006
                        • 1961
                        20mm is the absolute minimum you'll see, 25mm is normally as thin as you get. 4x100 to 5x120 1 of the bolts will interfere a lot, and one will interfere a little, so you can't use them with a 1 piece adapter. 4x100 to 5x130 can be made in single piece but 2 of the holes are really close. 4x100 to 5x100 works because you can reuse one of your bolt holes with a really long lugnut/stud. FK makes a kit.
                        If there's too much interference you can get 2 piece adapters made, you bolt a 4x100 part to your car, then with seperate hardware you bolt a 5x130 threaded piece on, then you bolt the wheel on. minimum thickness is like 35mm, often times wider.
                        • george graves
                          • 19995
                          Originally posted by Mossman
                          20mm is the absolute........|||||||.........often times wider.
                          Nice post.
                          With that said, at some point, if you are hell bent at running wheels that don't fit, you can also have them welded and re-drilled, painted and spaced(?). Just FYI.
                          • bignate948
                            • Apr 2006
                            • 542
                            i bought some adapters o long time a go but after looking at them i quickly changed my mind about putting them on my car. i would never put these on my car just do the conversion or buy the right wheels
                            • 153624
                              • Jan 2008
                              • 82
                              YUMMAAAY!!:giggle:
                              88 325 S-ETA --Wahwooweewah
