Picture of Water Pipe installed?
  • PaulEZ
    • Nov 2007
    • 100
    I'm in the process of switching from a 1987 radiator set-up to a late model set-up. I recently purchased the metal water pipe that runs across the front of the engine, and was wondering if anyone had a picture of it mounted? I'm not sure if I have the correct mounting points...
  • Sean
    • 5793
    here ya go:
    More here if you want to snoop around: http://photos.e30driven.com/v/supere...6+016.jpg.html
    - Sean Hayes
    • PaulEZ
      • Nov 2007
      • 100
      Cool! Do you know if the mounting points differ from 87' to 90'? I can't see exactly where it mounts up to...
      BTW nice job on the build!
      • Sean
        • 5793
        I can't tell you that one. I didn't think the earlier coolant systems had the metal pipe at all. :-\ Anyone know?
        Thank you! it's no where near that clean now - but I'm gonna give it a nice cleaning and do some gaskets next month! woohoo!
        - Sean Hayes
        • PaulEZ
          • Nov 2007
          • 100
          I can verify my 87' didn't come with the water pipe set-up, however I was hoping that the mounting accomidations may be there. Guess I'll have to check tonight...
          Tks
            • 34844
            I think it screws onto the water pump on one side, and the block on the other - mounting holes should all be there.
            • PaulEZ
              • Nov 2007
              • 100
              Had a chance to check...my 87' doesnt have the mounting holes, however I was able to make it work
