methods of paint removal
  • ethree
    • Aug 2007
    • 1216
    I want input on removing the paint from a urethane racing dynamics front spoiler, especially in regards to chemical strippers and such. The reason I ask is I want the logo part to look good and do'nt really want to spend hours with a box of toothpicks and some sandpaper and tape and I think sandblasting would be prohibitively expensive. Please share your methods for removing paint in hard to reach areas.
  • delfin
    • Nov 2007
    • 1064
    While we're at it what's the best method for getting the clear coat off my car?
    Advanded Delphin Division
    My e30s: 1987 325i/1994 318iT
    • uofom3
      • Jan 2004
      • 5392
      the clearcoat as in the clearcoat off the paint?????
      PNW Crew
      90 m3
      06 m5
      • uofom3
        • Jan 2004
        • 5392
        there is stuff called "bumper stripper". It is sold at large automotive paint supply houses. It works great on things like iS rear spoilers, etc. I'm pretty sure it is formulated in such a way that it wouldn't hurt your bumper. Since the part that you're talking about is pretty special/rare - i'd just go to a local auto paint supplier, tell them what you want, and they should be able to hook you up. I know that the stuff that said "bumper stripper" on it worked great on iS spoilers etc.
        PNW Crew
        90 m3
        06 m5
        • ethree
          • Aug 2007
          • 1216
          I'll have to check that out. I have a fantastic paint supply shop five blocks from my house, the only problem with them is they're open m-f 8:30-4:30 and I have a job. The is spoiler is urethane as well isn't it?
          • uofom3
            • Jan 2004
            • 5392
            I don't know if it's urethane but it's certainly some sort of composite. I think it would be safe for your spoiler. Just DO NOT use anything like aircraft stripper or whatever - that shit would dissolve your spoiler in a second. I'm sure the place down the road from you could help solve your problem in 5 minutes or less - but I'm also pretty certain that the bumper stripper is not so toxic as to eat the plastic.
            PNW Crew
            90 m3
            06 m5
            • der affe
              Technical
              • Dec 2005
              • 8452
              we use it, it works great!
              60% of the time it works every time!
              jk, buy it!
              • delfin
                • Nov 2007
                • 1064
                Yep that's the one. And don't tell me it can't be done because the PO did the entire back of the car and I don't know how it happened because I'd at least like the front to match.
                • der affe
                  Technical
                  • Dec 2005
                  • 8452
                  sand it off with a D/A or let the sun kill it. realize with out the clearcoat there is no sealer....rust will insue
                  • kowalski
                    • Jan 2005
                    • 1791
                    can't be done.
                    PO probably spraybombed the back of your car, or started to repaint. either way i would put some sort of top coat on the back.
                    • Desaevious
                      • Aug 2007
                      • 3810
                      "Low Odor Aircraft Paint Stripper." You can get it for 8.99 a quart at Adanved Auto or Auto Zone. Takes off layers of paint and is safe to use on plastics/metals...just use gloves...it BURNS.
                      SC*AR (Schwarz Army)
                      • delfin
                        • Nov 2007
                        • 1064
                        Originally posted by kowalski
                        can't be done.
                        Well I'm for sure getting it painted I just know that if I take it off myself it will save me some cash
                        • schmidty
                          • 1253
                          that is going to eat through anything that isnt metal! ...and it will strip down straight to the metal through the primer and all. I don't think that's what either of these guys is looking for!
                          • Tavern Gnome
                            • 2137
                            Unless there is something terribly wrong with the paint that is on it, like its peeling or completely spiderwebbed, I'd just sand out the "issue" areas and prep it for paint. Definitely don't use Aircraft Stripper on anything plastic. I have no experience with that bumper stripper stuff. If it was me and the old paint HAD to come off, I'd have a DA in my hand and some time to spare.
                            __________________
                            1987 Toyota Landcruiser V8
                            • uofom3
                              • Jan 2004
                              • 5392
                              shit no. DO NOT USE THIS ON PLASTIC.
                              PNW Crew
                              90 m3
                              06 m5
