help me make a decision.....
  • jonny4square
    • May 2008
    • 10
    so right now i have a 93 Honda civic auto... (no fun to drive at all just use as commuter) i have the option to trade to someone for a 325e pewter color 2dr 5 speed manual with 293,000 miles has service records and he says it doesn't leak any fluids the only thing wrong is that the turn signals don't work and the climate control fan doesn't work either. here are some pics of it
    tell me what you think.
    Thanks
  • eshghehBMW
    • 162
    sorry...but I would pass!
    • jonny4square
      • May 2008
      • 10
      why not?
      • TwoJ's
        • Oct 2005
        • 4908
        He probably said that because of the mileage. However, that may not be the best indicator of the condition. You need to provide more information for anyone to give you an educated opinion. When you look at the car, you need to check on the condition of a bunch of things. How is the interior? Have you looked underneath the car to see how it looks? Any rust anywhere? How does it drive? Good shocks, ball joints, bushings, tires? When was the timing belt last changed? Can you do (or have someone do for you) a compression test? It is very easy.
        All of these things are what you should look for, or ask the seller about.
        And by the way, where in Bellevue are you?
        • jonny4square
          • May 2008
          • 10
          im in between bellevue and issaquah on cougar mtn.
          • franko2490
            • 501
            I wouldn't do it if I were you ... but I am too poor to invest in not almost perfect cars ...
            Originally posted by E30_fiend
            Simply sexy.
            Originally posted by PУCCKAЯ_e30ka
            man... I took my little E30 outside for a ride, now 5sp.... there is no other car like E30... PERIOD. Don't know how to explain, but driving E30 is like having sex with a girl of your dreams, but the girl is a bit inexperienced, so you have to show her what to do and she will do it beautifully! ohhh man... after I got the 5sp tranny in it, it is all new love all over again! :)))
            • smonkbmw
              Professor
              • Jun 2006
              • 4549
              id want to know more maintenance history on the motor. almost 300k on a m20 although not unheard of, is quite lengthy for no rebuild history.
              • jonny4square
                • May 2008
                • 10
                good point thanks guys
                • cramer
                  • 1812
                  Exactly.
                  It all depends on what those records show. Oil changes and new wiper blades aren't going to cut it ;)
                  See if/when the suspension has been replaced, brakes, cooling along with any motor work. Those electrical problems are minor and if you're somewhat handy with a bentley and test light, you can fix them yourself.
                  Chris
                  90 Corrado/91 M3/01 M5
                  • e30damen
                    • May 2007
                    • 945
                    Branden,
                    I'm sure you'll be able to find something nicer than that before or at the e30 picnic. Good luck man.
                    PNW E30 Crew : 1991 E30 S50, 2000 E39 M5
                    Follow my S50 build
                    : MY S50 E30
                    Follow me on instagram : @damendesign
                    E30 T-Shirts | M3 T-Shirts /Prints
                    • BBY1104
                      Need to know more, and my blinkers did not work when i got the car becase the PO wired them wrong, get some more information on motor history.
                      • SynSyx
                        • Apr 2008
                        • 542
                        i would say keep the civic, you dont want to trade for the 325e and suddenly have to take on hundreds of dollars worth of repairs just to have a reliable commuter when you have one already
                        if your heart is set on the e30, save up and buy it, but if you need wheels, keep the civic
                        BavAuto ~ Bilstein ~ BBS ~ Scorpion ~ MarkD ~ Prolumen
                        Have you hugged a corner today?
                        '89 335iC (M30) - summer
                        '17 Mazda3 - winter
