painting shadowline
  • CntrlcoastE30's
    • 186
    Originally posted by der affe
    the originals were painted, so if properly done it should not be an issue
    As mentioned the prep. is everything. Adam had another excellent point regarding using a specific black (etch) primer coat. I use Wurth trim black paint (and have for 15 years) which is still holding up very well on mirrors, grills and headlight trim rings. It has been close to 3 years with a car that stays parked outside for 90% of the year.
    Adam, Ian and I are planning on a trim/shadowline day some time here in the future.
    • Dozyproductions
      • Jan 2007
      • 4682
      fair enough :) BTW: I missed the train.
      • CleanAzzE30z
        • Jan 2004
        • 11794
        Originally posted by VacMan
        Sorry Levent, but I beg to differ. If you prep properly and use the right products there is no reason it should chip. We did the 325is we bought my brother-in-law and the entire job is still fleck-free 6 months later. We sanded, cleaned, and used multiple coats of SEM trim paint. We also painted it off the car.
        Tim
        Agree 100%. I painted it whilst on the car with tons of prepping and many coats while waiting a good time in between and that was 4 years ago. Not one chip. SEM flat black trim paint is GOD!
        Mariano
        • BDSax
          Junkyard King
          • Mar 2006
          • 3594
          thank you mariano for a HELPFUL post unlike some of the other douchebags
          • der affe
            Technical
            • Dec 2005
            • 8452
            ouch! my feelings!
            first: remove all the trim except for the rear qtrs. (they are a pain because you have to remove the glass to reinstall the trim) and the sail panels (it is easy to break the retaining studs that are spot welded to the panel and you also must buy new retaining clips)
            second: thoroughly sand them with 320 grit paper
            apply a tack (light coat) of sem self etching primer, let dry, apply a second heavier coat, let dry.
            third: take RED scotch brite and lightly scuff the newly primed parts
            fourth: spray a light coat of sem trim black, let dry. now apply 3 more heavier coats. let dry in between each of the coats.
            fifth: reinstall the newly blacked out trim
            there, it gets no more thoroughly explained than that
            greg
            • CleanAzzE30z
              • Jan 2004
              • 11794
              No problemo.
              Mariano
              • CleanAzzE30z
                • Jan 2004
                • 11794
                ouch! my feelings!
                greg
                Exactly what I did.
