Did you run bumpstops with billy sports?
  • chrisesteschiro
    • 361
    Do they have internal stops? Or is it advisable to trim and run factory? I searched..........
    thanks
  • LovableSheep
    • 246
    According to the installation instructions I got with mine:
    Originally posted by Bilstein Mounting Instruction
    Do not reuse original bump stop, since BILSTEIN cartridge has built in bump stop.
    Fitment in reverse sequence of removal.
    • kamotors
      • Nov 2007
      • 7102
      i thought my instructions said not to, but i was in a hurry. im not running them, nothings happened yet. i read somewhere else that your supposed to cut the stock bumps in half but i'm not 100% sure that was meant for billy sports
      7speedshop.com
      • chrisesteschiro
        • 361
        Got the car apart tonight. The instructions said to use bumpstops. My car on oe springs didn't have any anyhow. I think I will just run without them and see how she does......
        • joshh
          • Aug 2004
          • 6195
          Always use bumpstops. Unless you want potential premature wear on the shocks.
          "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
          ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
          • sticksdaman
            • Apr 2005
            • 2987
            Do you have to order the bumpstops separately? Bc a friend of mine ordered his and they arrived sans bumpstops.
            Originally posted by ebelements
            Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
            • allwheeldrive
              • Jan 2008
              • 272
              I got the same with mine. No bumpstops here. Been working fine.
              • Jesse30
                • Jan 2007
                • 3936
                bilstein sports do not require a bumpstop, it has one built internally. it will not prematurely wear the struts/shocks if you dont run one externally.
                have a nice day.
                • chrisesteschiro
                  • 361
                  Thanks, I went without
                  • joshh
                    • Aug 2004
                    • 6195
                    have a nice day.
                    The fronts do not require bump stops the rears do. I just called Bilstein.
                    • scabzzzz
                      Estado de mierda de encargo
                      • 6871
                      My fronts bottom out more than my rears do, and my rear GCs are spun all the way down. Fronts are 3/4 down.
                      So basically, it doesnt matter. Use what you want.
                      • Teaguer
                        • Sep 2004
                        • 6167
                        Newbs for life yo !
                        • einstein57
                          • Jun 2007
                          • 10780
                          The instructions also say to not use oil in the strut housing. I was to lazy to poor my fluid out. Is there any bad about leazing it in there?
                          www.gecoils.com
                          • Aptyp
                            • 6584
                            HOW THE HELL do you put bump stops on Sports? i can see how on HD's and Touringm but on Sports? The shaft is so freaking wide, and they should have come with the blue boot around them that doesn't allow you to use a bump stop.
                            What are you guys buying? eBay stuff?
                            • Aptyp
                              • 6584
                              OH, and for the rears, if your car is low enough, you shouldn't ever use bilstein sports. With H&R Race, i had very little room for the shock to travel, so they're practically bottomed out all the time anyway. Use shock mount reinforcements, as you will need them soon.
                              And you still never need bump stops, unless your trailing arm travels past your upper spring perch.
