Did you run bumpstops with billy sports?
    A proper suspension uses non hesterisis bump stops. If you don't "need" them then you are either A) WAY to stiff or B) have a mechanical issue for instance something else bottoms before making use of said bump stops.
    Every hard bump encountered should be using the bump stop.
    88 325is
      I took it back apart and put in trimmed bump stops on the rear. I am running TMS solid rear shock mounts, AKG poly subframe and RTAB's. Feels great......
