Cheap Way to Correct my Camber??
  • diegom6
    • 4447
    Well I know there are available some camber correct plates out there, but I'm budget now, and was wondering if there is any info or home made correct camber plates , cuz my front cmaber is so negative that my tire will run in bad way.
    And I don't want to fuck up my new tires. :P
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
  • kencopperwheat
    King of Kegstands
    • 14396
    camber plates are cheaper than new tires.
    Originally posted by Gruelius
    • diegom6
      • 4447
      there is some way to make my own custom ones? I don't want to spend 120$ or so in buying one of those in ebay just for money issues, I already spent $250 fucking dollars in my new amp. since the old one went to hell.
      Also I'm saving for my next project, Turbocharge my Stroker Jeep with the that mosnter T4 that I have.
      There must be somewhere or somone that made this setup in the past, if I have the idea clearly, i can copy them in my shopp easily and cheap. :P
      • Digitalwave
        is a poseur
        • 6302
        Don't be cheap, if you can spend $250 on a frickin amplifier, spend the money on a nice quality set of camber plates like Ground Control.
        RISING EDGE
        • Jordan
          • 12916
          put your rear subframe in a vice and bend it in the middle.
          https://mtechniqueabs.com/
          • diegom6
            • 4447
            Damm I'm trying to get the idea but my english is not helping me out in this one!! lol
            Any other ay to explain it carefully? I mean what is exactly the subframe, I mean what part are you refering and what is "vice"?
            Thanks
            PS: Btw...I'm talking about the front, not the rear.
            • e30Matt
              • 5077
              P.S.: He was kidding.
              P.P.S.: Get some camber plates. Non-adjustable ones can be found as cheap as $100.
              • jbob
                • 74
                the ghetto way to correct front camber......(altho i would never do this on any car i own):
                slot the three holes on the strut towers where the strut bearing bolts to.
                i'm sure removing that material would probably weaken the mounting surface....and unless you using a washer that will bite down on the metal and/or a locking nut, you'd probably want to check the hardware on the strut towers often.
                m10 engine build photogallery
                • Brian 89 325i
                  • 1450
                  Anyone know of any good camber plates that use the stock diameter springs? Most of the solid plates out there are for 2.5 ID race springs.
                  Brian
                    • 37834
                    What kind of bodykit do you have? :jk:
                    Grover Beach, California
                    BimmerHeads.com
                    • ydubbs4
                      • 275
                      Brian
                      You looking for adjustable or fixed? I run RRT fixed plates on my M3, adds 1.25 degrees, pretty solid plates, but they'll raise your car 3/8" or so.
                      Will
                      • Digitalwave
                        is a poseur
                        • 6302
                        www.bmwbushings.com has a set of camber plates for less than $100, but they also raise the car.
                        RISING EDGE
                        • e30Matt
                          • 5077
                          B&!!!!!!! :) :jk:
                          • diegom6
                            • 4447
                            Those looks good TJ, and are not that expensive, I can pay it in few days, but it says will add "Allows approximately 3-1/4 degrees of negative camber" and I have negative camber already, I want postive since mine is very negative.
                            https://Allows approximately 3-1/4 d...egative camber
                            • AdamF 88iS
                              • 2051
                              Bend the strut tubes.
                              With a hammer.
                              And a vice.
                              Adam Fogg- '88 M3
                              Common sense- It's the new 'gifted'
