mechanical vs electrical oil gauges
  • franco90
    • 3185
    which ones work better?.
    I've always been proud of being a Marine.
    I won't hesitate to defend the Corps
    "Supersquad"
    ‎"Prostitutes are a sub-category of Amusement Parks"-
  • rThor432
    • Feb 2007
    • 3907
    Just run an oil feed to a mechanical guage like MB did/does.
    Honestly I dont know that there is much difference between the two.
    • franco90
      • 3185
      dude can you show me a picture of (location where Oil feed Starts) it I am trying to put a Mechanical Oil gauge in the IX
      "Supersquad"
      • rThor432
        • Feb 2007
        • 3907
        Might be able to if we have a MB at work tomorrow. Seems like all of the old ones need cluster work when they come in.
          • 34835
          my electric one seems to work just fine I think most issues people have are from bad grounding. a mechanical gauge just sounds like another leak waiting to happen, plus the electric one is really easy to hook up.
          • Borat
            • Jan 2005
            • 494
            ^ agreed. I'd prefer not to have 60psi of hot oil running into the cabin
            • DaveSmed
              • Apr 2007
              • 1406
              Mechanical gauges tend to be more accurate, and back in the day they used to offer a 270 degree sweep where the electrics were limited to 90 degrees.
              Times have changed a bit, and the accuracy difference and limitations of electrical vs. mechanical have diminished. Mechanical is still slightly more accurate and reliable but for most people, the difference comes in installation difficulty where electrical is usually the easiest option for most people.
              Also, someone asked about mechanical gauge failure. The amount of oil to enter the car will be relatively small due to the very small diameter of the tubing. Regardless, many racing classes forbid any kind of flammable liquid running into the cab. The solution? A gauge isolator. Oil runs up to a rubber diaphragm and acts to pressurize the ethylene glycol (or some other non-flammable liquid) that runs through the firewall and up to the gauge.
              -Dave
              2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
              Need some help figuring out the ETM?
              • DaveSmed
                • Apr 2007
                • 1406
                Oh yea, another thing.... Temperature gauges. Check them for accuracy! Check out this write up: http://www.madelectrical.com/worksho...mp-gauge.shtml
                Trust me, that one bit me in the ass HARD recently.
                -Dave
                • Draccent
                  • Jan 2008
                  • 52
                  I'll NEVER have another mechanical gauge in my cars. I had a mechanical oil pressure gauge that started leaking in my hyundai. The smell of oil never left the car. It was just above my gear shift console too, so it naturally ran all over the carpet. I've head stories of a-pillar mounted gauges coating windshields in oil. Electric all the way.
                  Eta dude. 8-)
                  • cramer
                    • 1812
                    Agreed.
                    Electrical gauges have never failed me in the past, plus no chance of leaks!
                    Chris
                    90 Corrado/91 M3/01 M5
                    • thull
                      • Aug 2005
                      • 191
                      running oil into the cabin doesn't seem like a good idea to me - electric gauge ftw
                      Brian
                      89 M3 2.5 - 91 318iS - 91 325iX - 06 X5 4.8iS - 03 525i Touring - Some 91 850s, and a few parts cars...
                      • franco90
                        • 3185
                        thanks every one for the help.
                        "Supersquad"
                        • DaveSmed
                          • Apr 2007
                          • 1406
                          Mechanical gauges are factory in many applications, as mentioned above, and they do just fine. Proper installation is key though, kinked lines at the back of the gauge are a common error with mechanical aftermarket gauges.
                          For the most responsive, accurate gauge, go mechanical. For the simplest to install, and most flexible as far as mounting options are concerned, go electric.
                          If oil/fuel is not allowed in the passenger compartment per class rules, and you wish to run mechanical gauges, use an isolator.
                          -Dave
                          • franco90
                            • 3185
                            This is the mechanical Oil gauge i be using thanks again
                            "Supersquad"
                            • Erick
                              Official R3V Drifter
                              • 11169
                              Bumping this up from the dead as I've been researching about this debate. It seems that the opinion varies from forum to forum, but the consensus seems to point towards mechanical gauges.
                              Obviously the leak seems to be the issue, but Vortex and another board (cant recall now) have suggested using copper tubing, which won't break and cause a leak.
                              I am inclined to go with the mechanical for the simplicity and cost. I'm sure even with copper tubing I'll be spending less with the mechanical gauge as I will with an electrical one. Once you start adding senders and metric adapters, things add up quick!
                              ..::Support FullOpp::..
                              FullOpp Stickers for sale!
                              Feedback Thread
