spring compressors?
  • deutschman
    • May 2008
    • 5958
    spring compressors?
    spring compressors does anyone in SF or near sf know of a place i can get spring compressors? i have checked all three kragen stores in sf. any one i can barrow them from? i have finished my back suspension and really want to get the front done!!!
  • backtrail69
    • Jul 2005
    • 4471
    harborfreight.com
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • Justin B
      Sikky Nar Nar
      • Mar 2005
      • 4273
      Ditto. Super cheap, but they work. You may be able to borrow (rent) some from a shop, but I wouldn't know where.
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        PepBoys "rents" tools for free. Just a deposit. They sell some shitty shocks/struts, so I'd bet they would have it available to ya.
        • gearheadE30
          • Jun 2007
          • 3734
          Check out autozone. They are the best place to rent from, I've found, because they have the biggest selection. Most of their tools are from Harbor Freight, I believe.
          Project M42 Turbo
          • jflip2002
            • Sep 2006
            • 4377
            If youre lowering it enough, you dont need a spring compressor. We didnt use one for my 60/50 kit. Otherwise, its probably worth the investment to get one from harbor freight.
            Originally posted by blunt
            • atomic
              • Jun 2007
              • 5691
              True but he will need them to tear the oem springs down from the struts safely. Or do as e30gangsta did... LOL
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                Fusebox cover eyeprotection.
                • deutschman
                  • May 2008
                  • 5958
                  thanks for the leads guys! hope i can find this pesky tool! its been a pain in the ass.
                  • Schmalex
                    • Jun 2008
                    • 97
                    If you decide to buy one i will split the cost with you. I need to overhaul my suspension soon. So one of these would be handy.
                    Originally posted by Mr Watsonsilver
                    Im a stright A student
                    89 325i (dead)
                    89 325is
                    • jflip2002
                      • Sep 2006
                      • 4377
                      Thats what I hear. We had a compressor on hand, and really didnt need it. We unbolted it from the top mount, and raised the car. It practically fell it, it took a pretty light pry to get it out. It really was pretty straight foward. The rears were a little tigther though..
                      • Van Westervelt
                        • 9365
                        Sears sells a decent set as well. If you are lowering it though, you wont NEED them, especially on install.
                        To take down stock units, just lay the strut down with the strut bearing on the soles of your shoes, with the tube and spring away from you. Use an impact gun to take the nut off the shock, and the items will shoot out a few feet, so point it away from anything nice or breakable. I have had one shoot out close to 20 ft. and old blanket can keep them semi contained.
                        • einstein57
                          • Jun 2007
                          • 10780
                          You can also gangsta the front springs off by unbolting the top strut bolt and then lifting up the car and then removing the strut body from the car. I would not recommend it but it worled for me in a pinch.
                          www.gecoils.com
                          • VacMan
                            • Apr 2007
                            • 2405
                            Autozone rented me 2 sets at the same time last time we did springs. Saved a ton of time having a set on the old springs and a set on the new ones for reassembly.
                            • 318isbmw
                              • Nov 2005
                              • 2843
                              I just pointed it at a wall when I took mine out since I put IE3's on after. Was kinda fun but be sure its at a thick wall, had a friend shoot the upper nut through some thin sheetrock.
