critique my alignment
  • chrisesteschiro
    • 361
    I just dropped the car with billy sports, h&r race, sways, new akg engine mounts, rtab, and subframe bushings, solid rsm's, adjustable camber castor kit for front, and aluminum m3 control arms. Here are my alignment specs....
    Left front- -1.2 camber, 10 degrees caster, .09" toe, 15 degrees SAI, 13.8 included angle
    Right front- -1.3 camber, 10 degrees caster, .08" toe, 15.3 degrees SAI, 13.9 included angle
    .1 degree cross camber
    .1 degree cross caster
    .16" total toe
    Left rear -3.1 camber, -.12" toe
    Right rear -2.8 camber, .25 toe
    Rear total toe .03"
    Rear total thrust angle -.27 degrees.
    I will eventually get a rear camber kit....does everything else look ok?
    Thanks
  • 2002maniac
    • 4260
    yeah, I would recommend that. your rear toe looks a bit funny (not terrible)
    If you are going to be doing much aggressive driving I would want at least -2.5 of camber up front. I run -3.5 and tire wear is hardly affected (bad toe really chews up tires)
    **EDIT** never mind your rear toe does look bad, I just realized that measurement is in inches not degrees. your car is doing the crab walk :) I'd get that taken care of.
    • chrisesteschiro
      • 361
      "Is rear toe of .03 inches bad? I think spec is .13 with a .25 range......"
      I see what you are talking about now , what would cause that? I think one of my subframe bushings might not be seated as well as the other.
