Maybe someone will have some insight to my little problem.
For what ever reason my Tach and Speedo have stoped working. All the other gauges work and Ive swaped in a new guage cluster and the same thing happens, no tach or speedo but everything else is fine. ( both cluster do function in other cars)
all my fuses are fine also. Is there a ground or power that the tach and speedo share? all my grounds above the brake peddle are tight.
is it just one plug that works the speedo and tach that you plug into the back of the guages? if so which colour plug isit and which wire would I be testing for power?
if anyone has any ideas about somthing to try that would be great.
Thanks
Thanks
