Hell on dyno?
  • diegom6
    • 4447
    Hell on dyno?
    seems to me Satan want's to unleash his powers!
    Now, could someone tell why say : Queens Street Racing 4 rotor engine dyno E46 BMW M3 4 Rotor GT60 Turbo made 1664hp and 1158lb/ft
    Is this a Mazda 4 rotor engine with some kind of BMW technology or what!?
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
  • backtrail69
    • Jul 2005
    • 4471
    weak
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • SamE30e
      • Sep 2007
      • 4319
      It's probably 20b housings with a custom 4 rotor e-shaft. And the E46 rotary car is just that, a e46 with a rotary in it, not a bmw made rotary.
      1985 325e 2.8 Turbo VEMS
      • SpecM
        • Oct 2005
        • 4531
        holy crap what caught on fire?
        wow this is my 666th post and you just meantioned Satan...
        1989 cirrisblau-metallic 325i
        • Tavern Gnome
          • 2137
          Hail Satan! That thing is intense!
          __________________
          1987 Toyota Landcruiser V8
          • 318isbmw
            • Nov 2005
            • 2841
            Rediculous, but I'll be amazed if they can put that to the ground. Kinda worthless w/o being able to put it down. Incredible none the less.
            • e30pwr
              • Oct 2007
              • 642
              fire, that would be the rotary backfiring. 4 rotors were only used in the 787B racer iirc. The normal rx8 only has two rotors and look at the turbo potential of that monster.
              • diegom6
                • 4447
                That's a signal...beware! :p
                Here is the video
                • T Verdier
                  • Aug 2007
                  • 2636
                  why put it in an e46? i guess they like the body style?
                  • Rustyduktape
                    • Jul 2008
                    • 592
                    that's mighty intense. haha.
                    1987 325is Black/Black
                    -91k
                    -Stock (mostly)
                    • e30guydownunder
                      • Jul 2008
                      • 874
                      I'm pretty sure its two 13B housing bolted together with a special 4 rotor shaft as mentioned. Its an all out drag car so it can put down whatever horsepower you throw at it.
                      - Chris
                      Project M42 - 255 @ 19 psi
                      • SamE30e
                        • Sep 2007
                        • 4319
                        4 rotors making big power are usually 20b housings with another 20b housing attached. The 20b is out of the Cosmo.
                        The 787B car used a 3 rotor.
                        • e30guydownunder
                          • Jul 2008
                          • 874
                          12A/13B is a 2 rotor housing
                          20B is a 3 rotor housing
                          26B is a 4 rotor housing that was only used in the 787B Lemans race car....
                          the el cheapo way to make a 26B in todays society is by bolting two 13B's together in a line... giving 4 rotors...I would be interested to know why you think two 20B housing would be used.
                          Well atleast the thing about the two 13b's is how the aussie car was made, im not sure if there are other BMW drag cars running effectively 26B engines....
                          Cheers,
                          Chris
                          - Chris
                          • SamE30e
                            • Sep 2007
                            • 4319
                            Cheers,
                            Chris
                            My bad, I thought the 787b was a 3 rotor. But the 4 rotor my brother designed uses 4 20b housings, maybe it's not common.
                            • e30guydownunder
                              • Jul 2008
                              • 874
                              I guess with the above information being about the extent of my rotoary knowledge....as long as you make a custom shaft and bolts/dowels, it doesnt matter what housing you use.....just need:
                              End Plate | Rotor Housing | Intermediate Plate | Rotor Housing | Intermediate Plate | Rotor Housing | Intermediate Plate | Rotor Housing | End Plate
                              - Chris
