Cabrio Interior Swap Question
  • BDK
    • Jul 2008
    • 684
    Can I take the interior from a later model power top car and install it in my 87 manual top?
    There is no cut out for the top release but can I not just use the original piece to mark where it needs to be cut and use a dremel?
    Or did BMW change things and it won't work?
    Has anyone done this before?
    Thanks,
  • Lair
    • Apr 2006
    • 1553
    It's all interchangeable.
    McCain's military draft: Are you willing to bet your life?
    • Stevie30
      • Apr 2007
      • 1534
      BDK, If I remember correctly, your panel is embossed on the back side where the cutout should be. What Lair said +1. Good luck.
      1991 325ic and 1991 318is
      • VacMan
        • Apr 2007
        • 2405
        It's not exactly interchangeable, but it's close enough. Cutting the vinyl and the spot where the handle goes is easy enough.
        • BDK
          • Jul 2008
          • 684
          Thanks guys!
          • E30ownerwithanopinion
            • 1526
            if the new one is in really good contidion... you cant swap it. Just throw it away.... infact let me help by coming over and picking it up for you.
            • oekundar
              • Sep 2007
              • 964
              are you talking about the rear side cards? If so...I'd be interested in pictures and progress.
              BMWCCA #389756
              • BDK
                • Jul 2008
                • 684
                OK, sure, and thanks for being so helpful....:DLOL
                I will find out soon, here I guess, still in negotiation but working on it...
                will post my findings with pics when done...
                Thanks again,
                B
                • E30 Cabrio
                  • Oct 2006
                  • 1954
                  I changed my interior from Navy to Black by removing the rear panels and front door cards, door handles and map pockets and spraying them with black vinyl paint, along with the boot cover.
                  I dyed my rear seats Black using leather dye, and I swapped out my fronts for a nice pair of Black Cabrio heated sport seats that I got for cheap on craigslist.
                  The carpet is still a light blue color, but the floor mats cover 90% of it.
                  Came out nice and the vinyl paint has held up fine. No fading or chipping or peeling.
                  I also used the extra set of headrests and dyed those black and got some brackets and put those on the back seats.
                  The entire swap cost less then $300.00 for the front seats, leather dye and the vinyl paint.
                  That and a few hours of my time.
                  1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
                  Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
                  Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
