Damn GC collar!
  • rwh11385
    lance_entities
    • 18403
    Damn GC collar!
    After finally confirming the size of the allen tool, and getting dirty/scratched hands fucking with it, I have given up.
    I cannot get the allen bolt thing loose so that I can adjust my height. It sucks.
    Any advice? I'm hungry, I'm going to get something to eat.
  • Digitalwave
    is a poseur
    • 6298
    Try using a breaker bar, if not spray PB Blaster on it and let it soak in, then try again.
    RISING EDGE
    • rwh11385
      lance_entities
      • 18403
      I don't know if a breaker bar would fit.
      The problem is the allen wrench tool doesn't give the proper leverage, and I have a 3/16 allen bit, but it is not long enough to fit into and have any effect.
      I will probably have to find a longer bit and then use a rachet....but fuck it.
      p.s. Wifi E30 Driveway Wrenchin'.
      • Mystikal
        Wheel Fitment Expert
        • 9602
        When I adjust them I always leave the slot at an accessible spot, make sure you do that once you set them. Oh and you really don't need to torque the hell out of the thing down, fingertip strength is plenty.
        • rwh11385
          lance_entities
          • 18403
          tell my damn PO that.
          eh, i don't mean that. I am grateful he put GC's on the LMR325.
          • Bill 84 318i
            • 1600
            My front ones are getting tight after only a year. I just use a 10mm deep socket (and sometimes 3" extension) as a breaker bar for the allen wrench.
            • rwh11385
              lance_entities
              • 18403
              well, niether have been touched for over a year. I'm going to try again later.
              I'll use that hint.
              • 808BMW
                • 2910
                Get a small wrench, stick the allen wrench through the circle part of the wrench, apply pressure to the wrench. Just watch out, you can bend your allen wrench pretty easily.
                • Beej '86 325es
                  • 2639
                  You really don't even need to wrench them tight. My H&R rear adjusters don't even have any set screw or anything to hold them in place, but then the threads are a little finer.
                  -Brandon
                  '86 325es S50
                  '12 VW GTI Autobahn DSG
                  '03 540i M-Sport (sold)
                  '08 Jeep SRT-8 (sold)
                  For sale:
                  S50 TMS chip for Schricks
                  • e9nine
                    • 1890
                    Disconnect the shock, take the spring & perch out and get to work with a vice.
                    So far I have never had any probs (knocking on wood) when I have had to adjust my ride height. I will be doing it again soon so let see if I have just hexed myself :roll:
                    • aaron_silva
                      • 1785
                      I dont think I could get the threaded sleeve off of my trailing arms if I wanted to. Those things are on there good.
                      Aaron
                      • EVOIIIM3
                        • 315
                        If it's in the rear, just take them out! Adjust and put back in.
                        If you are having trouble getting at the fronts, you have other problems.
                        • surebimmer
                          • Jan 2004
                          • 978
                          I'm sure a BFH would get them off the trailing arm.
                          • e9nine
                            • 1890
                            I'd say torch the fucckkers. Heat does wonders. BFH and a torch will perform miracles. If it's stuck that firmly on the trailing arm, use it to your advantage for now. Get a cheap torch from Pepboys or whatever, make sure it has all the parts, get a lighter and you'll be in business.
                            • theberglar
                              • 143
                              I had the same problem on one of my GC collars. It bent my allens and would not come loose for anything. I used a cheater bar, sprayed PB, everything. I ended up twisting it to go up/down by carefully placing a screwdriver on it and hitting it with a hammer. It would budge a tiny bit, so i did that until I turned it to where i wanted the height to be. Good luck
