s52 is in
  • gae30
    • May 2004
    • 87
    s52 is in
    Here are some pics. I will work on sound clip once I fix an annoying exhaust leak.
    http://www.casualescapes.com
  • Jordan
    • 12916
    Looks like a S50 to me, not a S52.
    Clean install either way.
    https://mtechniqueabs.com/
    • LikeCDoos
      • Jan 2004
      • 2522
      that is a clean looking 4 door. Nice and simple. Congrats
      • M3 Ryan
        Site Sponsor
        • 2298
        That looks very nice!
        Just make a heatshield for that HUGE K&N and you will be set!
        Nice job!!
        '88 M3.2 S54 Lachssilber/Black
        '07 335i Alpine/Black Sedan
        '12 X5 3.5i Alpine/Black
        iS Splitters For Sale, PM ME!
        • mgold
          • 709
          A very clean install, one of the nicest I've seen.
          • trent
            Some people use the S52 valve cover to make it look like an S50 for smog regulations -- that way it looks like OBD1.
            But you are right, they also put the shitty cast iron manifolds onto the engine.
            I also think you should dump the engine fan.
            • gae30
              • May 2004
              • 87
              So it's supposed to be an s52 converted to obd1...what's the definitive way to tell - I need to make sure I didn't get ripped off....
              :x
              • trent
                :x
                Well externally just looking at a few things...
                Exhaust manifolds are S50
                Pink top injectors are S52
                Valve cover is S50
                real way??? get vin number. Even this can be tricky. The cylinder head contains a vin number. I cannot remember if the actual engine block does or not either. S50 heads do fit S52 bottom ends and vice versa -- therefore the only *real* way as far as i know is to measure the crank stroke on the bottom end. I am sure there are probably some different markings on the blocks between S50 and S52, but I do not remember them.
                • skat 325is
                  • 296
                  I always thought S52 had individual throttles ??
                  Or is it only the euro version ?
                  • M42Technik
                    • 9781
                    Looks sick. Very clean install, and yes that cone filter is gigantic.
                    What suspension are you running? Great stance.
                    Reminiscing...
                    • trent
                      Euro...
                      • gae30
                        • May 2004
                        • 87
                        Be honest with you - I was a little suprised at how big the filter is - it really doesn't fit all that well - may have to swap it out in the near future - doing the job now - though
                        The suspension - that's a tough one - it was on the car when I got it - but this is what I know - it's HR springs that drop the car about 1.5 inches all the way around. Also as part of the conversion I ended up with these:
                        They allow for clearance of the exhaust headers...
                        • royalflush313
                          • Mar 2004
                          • 2070
                          what a sleeper...
                          those wheels are nice too.
                          ~ Go Canucks Go! ~
                          • gae30
                            • May 2004
                            • 87
                            Originally posted by royalflush313
                            what a sleeper...
                            Thanks. It would be more of a sleeper if it weren't so damn throaty - it's hard to suprise someone in this car....
                              • 37832
                              Looks like an awesome car, I really want my next E30 to be a 4 door I think.
                              What exhaust are you or will you be running with the swap?
                              Classic BMW Specialists
                              Grover Beach, CA
                              www.BimmerHeads.com
