Eta
  • bddog
    • 351
    Eta
    Just wanted to say-- I own an eta. Gas mileage plus. Came back from the Big Trees this week. 75 mph-34 mpg - from Fresno to Redondo Beach . Only time I've ever had anything to say about an e over an i. Won't last, I know. Probably regret it already, knowing you guys.- Steve
  • viali8
    • Nov 2005
    • 673
    love the eta motor
    • TDE30
      • 7042
      I still miss mine when I'm at the gas station 3 times a week.
      - Trey
      E90 325i/6 (ZSP, ZPP, ZCW)
      E36 325i sedan
      E30 325i sedan
      Volvo 945T
      • Stephen
        Шлем ишака
        • 10774
        i like mine, esp after the chip :) good on gas too.
        • FLUTE007
          • 485
          love mine, but i only get about 27mpg. the chip and a 3.73lsd, and will do that.
          • rThor432
            • Feb 2007
            • 3907
            Yep, no matter how hard I beat on it I cant get less than 33 mpg.
            Trey, the b25i motor shouldnt be that bad. Sounds like you need an S50/2--- gas mileage and performance :).
            • buzdof
              • Jan 2008
              • 125
              Wow, my eta can't get any better than 22 city, 25 highway :(
              Edit: stock motor/diff/tire size but the car did have a 5-speed swap done. markD chip increased mpg a little, up from 19/22...
              New rotor/cap/plugs/fuel filter/air filter/fuel pump/fuel psi reg... what else would affect mpg so much?
              • SamE30e
                • Sep 2007
                • 4319
                Mine gets shit milage.
                1985 325e 2.8 Turbo VEMS
                • Jand3rson
                  • 37587
                  I love my eta motor, especially with the Turner Motorsport chip. Tons of low end grunt, and low highway revs at speed.
                  • TDE30
                    • 7042
                    It should be noted that I only throw in $15 here, $20 there when it comes to gas. I rarely fill it up unless I have unusually large drug deal the preceding week.
                    - Trey
                    E36 325i sedan
                    E30 325i sedan
                    Volvo 945T
                    • e30lov
                      • Jul 2008
                      • 1597
                      my last tank on city miles in my 318i was just over 370 miles. meh
                      `92 325 vert - `90 325 coupe `99 m3 - Instagram @e30L
                      • rThor432
                        • Feb 2007
                        • 3907
                        Bad afm, coolant temp sensor (to dme), and maybe the O2 sensor can affect it.
                        I had a bad afm, so my car wouldnt run at all. I put in a spare b25i afm, thinking it would be ok, but not perfect. I was way off-- I got maybe 8 mpg on the highway. I was running very rich. So afm affects that quite a bit.
                        Coolant temp sensor will tell the injectors to stay open longer if the sensor is reading a temperature that is below what it wants to see.
                        O2 sensor reads the amout of hydrocarbons in the exhaust gases, and an incorrect reading can affect how rich/lean you are running.
                        • buzdof
                          • Jan 2008
                          • 125
                          I replaced the O2 sensor a few weeks ago and the coolant temp sensor a few months ago. Would having a 72*C thermostat affect anything?
                          • 88driftIS
                            • 300
                            Not mpg's, well not to your extent.
                            • learningcurve86
                              • May 2008
                              • 715
                              i get 23-26 mpg on average per tank. i would kill to brake 30. I really need to get a new O2 sensor... I like etas though... but then i haven't had an i
                              Greg
