16 x 8 et23 wheel...will it fit?
  • bert
    • 306
    opportunity to purchase some nice wheels
    at a good price...16 x 8 et23...tires have never been
    mounted, but the seller claims that these are
    correct fitment for e30 with 225/45/16...i can't
    find any info anywhere online regarding correct
    offsets for an 8" rim...7.5" is the widest i have found...
    i have heard that there are varying degrees of fender
    clearance depending on the model year...are these going
    to fit on a 1990 325is?!
    thanks
    bert
  • 808BMW
    • 2910
    Re: 16 x 8 et23 wheel...will it fit?
    thanks
    bert
    Hopefully it will fit, because I want to run 8" wide rims and I was thinking of trying for et23. I'm pretty sure both Randy and Jeremy have 18x8" rims that are et23, that's what I'm planning on... Shouldn't make a difference if its a 16" rim.
    • Kavkazia
      • 394
      AndreNY is the person to talk to about it.
      95' M3.
      90' 325i Turboed.
      87' 325eS Fixed.
      • Digitalwave
        is a poseur
        • 6299
        Sounds like a perfect fit to me. Got a pic of the wheel?
        RISING EDGE
        • Bill 84 318i
          • 1600
          Here's my logic.
          People run et20 17x7.5" wheels with 215's and they rub on dumped cars. So your wheel will be 3mm more inside (et23), but be approximately .25" (6-7mm) wider on each side of the offset. You can probably do it with either fender rubbing or cutting.
          • bert
            • 306
            should i run a narrower 205/50/16 instead of a 225/45/16...
            i would prefer inaccurate speedo over rubbing...
            bert
            • Digitalwave
              is a poseur
              • 6299
              205/50-16 is only .1" oversized, its not a big difference.
              RISING EDGE
              • Brew
                • 3060
                '91 318is
