the left front wheel bearing has play because you took the axle out... if you roll a car around with axles out you should bolt the bearing together.... looks like a fun project though.... best of luck, and I hope you aren't setting the cylinder head down on the valves
What I have been up to... dub content
Originally posted by e30evolution View Postthe left front wheel bearing has play because you took the axle out... if you roll a car around with axles out you should bolt the bearing together.... looks like a fun project though.... best of luck, and I hope you aren't setting the cylinder head down on the valves
Its not on the valves, all of them are shut and its propped up on one side so they aren't touching the bench.Rollin' with a Geistkuchen
Originally posted by Mr. Anderson View PostWoah! I had no idea that's what a VR6 looked like inside, that piston orientation is crazy! I'd just never seen one taken apart before.
Leave it to VW/Audi to come up with all the wild-ass engines. :DRollin' with a Geistkuchen
