Funny little clutch pedal problem
  • Fel
    • Jun 2008
    • 246
    I'm having an issue with my pedal.
    Sometimes (not always, but frequently) when driving, when I release the clutch pedal, it doesn't return 100% of the way. I can take my foot off the pedal, stick my toe behind it, and pull it towards me about a 1/4 inch (measured in my foot's eye.... no idea the actual distance).
    What can be causing this? The clutch itself engages just fine, but I feel uncomfortable with the way the pedal behaves... especially because the crossover is very shallow.
    Any help?
    "He speaks French..... in Russian."
  • e30frosh
    • Dec 2004
    • 2170
    Clutch master cylinder or slave cylinder. Most likely the master. About 60 bucks at your local parts store.
    Every day I wake up we drink a lot of coffee and watch the CNN
    Every day I wake up to a bowl of clover honey and let the locusts fly in.
    Lobsterbacks attack the town again
    Wrap all my things in aluminum
    Beams of darkness streak across the sky
    Pink rays from the ancient satellite
    Every time I look out my window same three dogs looking back at me.
    Every time I open my windows cranes fly in to terrorize me.
    • kishg
      • Sep 2006
      • 2624
      master..
      '12 F30 328i Sport Line
      '91 SpecE30 #523
      '00 Ford F-350 Dually Tow Vehicle
      BMWCCA #360858 NASA #
      128290
      • Fel
        • Jun 2008
        • 246
        Thanks, good to know...
        Shit, I'm not gonna be able to do that myself am I.... gotta drop the transmission to get at it?
        • DCColegrove
          • 2748
          Transmission stays where it's at.
          The clutch master is way the hell up under the dash...Kind of a job for a pro...Or at the very least a very patient dude.
          • regnu
            • Sep 2006
            • 1048
            no but it is a pain in the ass even with a lift.
            It is connected to your clutch peddle. I had the hardest time getting the line to thread onto it after I put the new one in. If possible I suggest putting the line on the new master before mounting the new master up (I don't remember if this can really be done). Be careful when pulling the feed line off in side the car, don't spill break fluid every where and don't break the plastic nipple (7).
            John
            • Fel
              • Jun 2008
              • 246
              That looks like a major pain in the ass. I think I'll let my mech have a crack at this one.
              Thanks for the help guys, at least I know where to start!
              • scabzzzz
                Estado de mierda de encargo
                • 6871
                You can probably do it, but its just enough trouble to say fuck it and pay someone else to do it.
                • e30frosh
                  • Dec 2004
                  • 2170
                  You used a lift? I did mine in teh gravel with a jack on a road sign....
                  • abepark
                    • Feb 2006
                    • 384
                    if the clutch engages and disengages fine, and the brake fluid level stays the same. I would be suspect to the return spring or air in the line. there's spossed to be some play in the clutch pedal
                    its easy to bleed the clutch system with two people. I don't know why people are saying you have to get under the car for the clutch master cylinder, its under the dash you can do it in your driveway. Yes its tight and you need some patients and the right tools. Have an empty container so when you do pull the clutch line off the master you have somewhere to put the fluid.
                    • regnu
                      • Sep 2006
                      • 1048
                      You sir are more hardcore than I.
                      good point about the return spring. So were you able to pull the line that goes to the slave inside the car to get it off then? How did you bleed it with out getting under the car?
                      John
                      • abepark
                        • Feb 2006
                        • 384
                        yea forgot about bleeding it once you got the master in...gotta get under the car for that. you can bench bleed the master so that Most of the air is removed, and you can probally get away without bleeding the system.
