E30 engine swap options
  • CincinnatiKid
    • Nov 2007
    • 716
    Right now I have the m42, but am wanting some more POWAAA!! (Jeremy Clarkson), so I'm looking into some engine swaps. What're my best options for motors as far as ease of maintenance, aftermarket availability, and not going to break the bank? I was thinking s52, but I've noticed they're hard to come by, and no I don't have the money for s85 twin turbo.
    1990 S50 goodness.
  • z31maniac
    • 17566
    Search smarter with SearchGPT Plus, your free Chat GPT alternative for writing, learning & productivity. Try GPT search with instant, intelligent results.
    www.gutenparts.com
    • OrganicMechanic
      • Jan 2008
      • 1719
      I was going to say the same thing.
      join the E30 Cabrio owners gruppe
      click here for details
      • CincinnatiKid
        • Nov 2007
        • 716
        ok I guess I'll do some more searching then
        1990 S50 goodness.
        • 92 mtechnic cabrio
          • 4907
          M20
          m30
          m50
          m52
          m60
          m62
          s14
          s38
          s50
          s52
          R.I.P 07/01/09 - 04/23/10 :(
          • E30_fiend
            • Apr 2006
            • 7348
            Jon, you forgot the ever so sexy S62. The S38. . . Mmmm. . . Can I has new boxers?
            • Car Addict
              • Mar 2007
              • 1100
              also an s54 or an m70 but those require a bit more time and fabrication
              • cferb
                • 1442
                s50 is the easiest with the most bang for buck. Not to mention if it isn't enough, a turbo will suffice for any amount of power you want. I hear an s52 isn't much more work though.
                • Ral
                  • 1486
                  there's someone on s14.net swapping an sr20det into an M3. Really, if you have the time and money you can put anything in there.
                  Also, look up the LS-1 into an e30 on this board. Just to get you thinking.
                  sigpic89 M3
                  • Bimmerman325i
                    • 6854
                    Easiest in terms of time and money:
                    M/S50/52
                    M30
                    most expensive: S38/S54/M70
                    2017 Chevrolet SS, 6MT
                    95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                    98 M3/4/5 (stock)
                    • StereoInstaller1
                      GAS
                      • 22679
                      The way I see it, if you know how to swap an engine, you don't need to ask which one.
                      IMO, the best "bang for the buck" has to be the M30.
                      Closing SOON!
                      Thanks for 10 years of fun!
                      • GaryE30
                        • 4791
                        LS1 swap is pretty involved, but if you have the fab skills and money it would be pretty amazing. There are a bunch of things to do such as cutting and reshaping the oil pan. Also I know the booster has to be moved and I think it has to be custom, but you may be able to use the e34-v8 setup.
                        Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
                        • OrganicMechanic
                          • Jan 2008
                          • 1719
                          ford 302
                          caddie northstar
                          2jz
                          sr20-det
                          b16a2
                          those are great also...
                          j/k
                          • gearheadE30
                            • Jun 2007
                            • 3734
                            I'm a huge fan of the M30/M88/S38, and the M30 is easy enough to come by. Very reliable, too.
                            Project M42 Turbo
                            • cferb
                              • 1442
                              True, but the s50 is also good, more expensive, but more power, and a more modern engine. Either way is good.
