Help tonight if possible
  • E30SPDFRK
    • 5695
    My car keeps blowing the tach/temp gauge fuse. Like- the second I put it in it blows. I checked all of my wiring from where I spliced the harnesses together (m30 swap) to the c104 in the glovebox, but I found no shorts. I suck at electrical, so I don't know where to check next. Any help?
    The reason I need this tonight is I need to drive to school tomorrow, and I have been having cooling system problems lately.
    Byron
    Leichtbau
  • Julien
    • 7471
    check the reverse wires that go down to the gearbox.. mine had stripped and grounded themselves causing that same fault
    good luck
    Julien
    Build Threads:
    • E30SPDFRK
      • 5695
      Those are the ones that start under the shifter console and go through the shifter hole, right?
      Byron
      Leichtbau
      • E30_Pare
        • 7801
        yes. take out your shift boot and lift up the foam piece and you should be able to see a wire.
        DREWLIENTE
        1$ PShops PM me
        • E30SPDFRK
          • 5695
          The reverse wires on the top side of the car look fine afaict, I cant check underneath because it is snowing. Is there anything else it could possibly be that I can check from above in the meantime?
          Byron
          Leichtbau
          • Optimator
            • 1396
            Is 10 or 21 blowing?
            -OVULATOR (as named by jflip2002)
            Past Cars: Schwarz 1990 325i-2 (crashed), Calypsorot 1991 325i-2 Sport (rear ended)
            Now: Blake-stitched mediocrity :(
            • E30_Pare
              • 7801
              Mine looked fine too, but then I pulled on the wire and I found out that it was cut in half.
              DREWLIENTE
              1$ PShops PM me
              • E30SPDFRK
                • 5695
                10
                I tried pulling pretty hard and neither of them pulled up. There is a little nick in the casing of the brownish one, but it wasn't/isn't touching anything. I wrapped some electrical tape on it just to be sure anyways.
                Byron
                Leichtbau
                • E30SPDFRK
                  • 5695
                  Anything else it could be?
                  Byron
                  Leichtbau
                  • digital_cowboy
                    • May 2008
                    • 335
                    It could be a short in the wires down at the tranny.
                    -Will
                    1987 325is, 1989 325i, 1997 318i
                    Parts for Sale
                    • E30SPDFRK
                      • 5695
                      I got that.
                      I meant anything I could check from above.
                      Byron
                      Leichtbau
                      • E30SPDFRK
                        • 5695
                        I checked the reverse wires the best I could this morning without removing the driveshaft or exhaust. I dropped the back support and looked them over, but I didn't see any signs of arcing or shorts.
                        The first 2 times the fuse started blowing, I had been higher up in the rpm range. I thought it may have something to do with the 4 cyl tach I have getting overloaded, so I pulled the tach out and tried to run it, but that made the car run like shit. I guess the tach completes some circuit?
                        Byron
                        Leichtbau
                        • E30SPDFRK
                          • 5695
                          Any more help, guys?
                          Byron
                          Leichtbau
                          • E30SPDFRK
                            • 5695
                            So I fixed the stumble (no gas to the pump while I had one side in the air )
                            I have no fuse in right now, so explain this: When I start the car, the tach comes to life for 3 seconds then dies. I checked the amps through where the fuse plugs in, but got nothing. There is 13.xx volts there though.
                            Think it could be getting power through the short for the 3 seconds before it dies?
                            Byron
                            Leichtbau
