Random beep noise?
  • ethreezy90
    • 103
    Random beep noise?
    Hey guys so last night i was on the freeway going about 80mph(if that makes a difference) and out of nowhere i heard a random beep similar to a elevator beep tone. its not the first time ive heard this but i want to know what it means? no lights came on all my doors were closed nothing out of the ordinary. i might just be dumb but someone tell me what it is if you know? thanks.
  • AWDE30
    • Jul 2006
    • 762
    There is a way to set the OBC to beep when a certain speed is reached.
    • E30 Cabrio
      • Oct 2006
      • 1954
      If you have a full OBC, it was probably beeping because the temp hit 37 degrees or below, which is when "Black Ice" can form in shaded areas, such as freeway underpasses.
      Your OBC will beep to warn you of potential black ice conditions.
      It's been cold here in the SF Area at night and in the AM, so that's probably what you heard.
      Check your OBC next time you hear it.
      1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
      Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
      Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
      • Lazr111
        • May 2007
        • 340
        Speed gong? The 13 button OBC has a feature that you can program a certain speed, and when you hit that speed it gongs and I'm pretty sure the button lights up.
        It would be the top right button.
        If life passes you by... Downshift.
        • N2MYE30
          • Oct 2007
          • 5536
          Originally posted by e30 cabrio
          if you have a full obc, it was probably beeping because the temp hit 37 degrees or below, which is when "black ice" can form in shaded areas, such as freeway underpasses.
          Your obc will beep to warn you of potential black ice conditions.
          It's been cold here in the sf area at night and in the am, so that's probably what you heard.
          Check your obc next time you hear it.
          +1
          COTM
          • blunttech
            • 12850
            it could also mean youve reached your floor and you should exit
            sales@blunttech.com
            www.blunttech.com
            Like us on Facebook
            • DCColegrove
              • 2748
              Is the memo activated?
              It'll beep every hour if it is...
              Weird... I know.
              • kronus
                • Apr 2008
                • 13032
                You get those e30-driving waking dreams too?
                cars beep boop
                • Stephen
                  Шлем ишака
                  • 10774
                  Weird... I know.
                  +1 I had my memo on for a while. I think i just pressed "memo" and it went off. Then i pulled the speaker out of there cause god it is loud.
                  Oh yeah, and for weight reduction.... ?
                  • DCColegrove
                    • 2748
                    For weight reduction?
                    Just throw the whole thing and it's wiring away...
                    • Stephen
                      Шлем ишака
                      • 10774
                      I was mostly kidding, the noise seemed unneccasirly loud, and i also broke my knee bolster, so out they went... Im replacing it with an analog clock if i ever get around to it
                      • DCColegrove
                        • 2748
                        I know you were kidding...
                        I still wonder what the hell that memo beep is for anyway.
                        People would schedule appointments at the shop all the time because of it.
                        • ethreezy90
                          • 103
                          the temperature thing makes sense i think thats it because it is freezing the in bay at night lately. i do have a full obc but the blub is burnt out? so it doesnt light up and it is a bitch to take out any suggestions on replacing it? i have another one with a good bulb.
                          i dont think its the speed because i go faster than 80 and it never beeps.
                          thaNKS.
                          • E30 Cabrio
                            • Oct 2006
                            • 1954
                            thaNKS.
                            I'm not sure, but I think when the OBC beeps to warn you of black ice conditions, it will change to "Temperature" display mode and flash the current outside Temp.
                            Either way, I'm pretty sure that is what is beeping.
                            Speed warning, memo, and your stock tape deck requiring cleaning are also other things that would beep while driving.
                            I've also heard that the rear defroster will automatically engage when reaching 37 degrees or lower outside, but that may only apply to later model BMW's.
                            • Nic01101011
                              • Jan 2008
                              • 1549
                              my car emits 3 beeps at times, anyone know what that means?
