Help..Name that sensor and purpose
  • GT BMW E30
    • Nov 2008
    • 2491
    I have a 325I with a 325e engine. Can you tell me what the 4 sensors are and what is the purpose. The two that is not connected are they even need?
    I know...why in the hell did I put a 325e engine in a 325I. I bought the car with a blown engine for $800. Bought the 325e engine for $150 with 78,000. I was like damn I am on top of the world. Ask me now....It is lonely down beneath a rock.
    I do need help known what the 4 sensors are, their duty and if they are even needed?
  • James
    • Oct 2004
    • 334
    buy one of these.
    • GT BMW E30
      • Nov 2008
      • 2491
      Originally posted by James
      buy one of these.
      I have some books in glovebox. I am going to check tomorrow. Anyone else have any suggestions?
      • SamE30e
        • Sep 2007
        • 4319
        1 - Temp time switch
        2 - Water temp sensor
        3 - Temp switch (A/C fan I think)
        4 - Engine coolant temp sensor.
        1985 325e 2.8 Turbo VEMS
        • GT BMW E30
          • Nov 2008
          • 2491
          Check again. I know number 1 is coolant temp switch.
          • mikeedler
            • 6707
            1= guage temp switch
            2= motronic temp switch--could be the other way though
            and the other 2 have to do with automatic trans/ and or air cond.
            • GT BMW E30
              • Nov 2008
              • 2491
              I am going to have to do some more research.
              • OrganicMechanic
                • Jan 2008
                • 1719
                free online manual
                link
                join the E30 Cabrio owners gruppe
                click here for details
                • DaveSmed
                  • Apr 2007
                  • 1407
                  1- Coolant temp sensor, used by DME for fuel mixture table lookup, and on Motronic 1.1 idle speed control. On Motronic 1.0, this signal is instead split to the Idle control module for the same purpose.
                  2- Coolant temp sender, for your instrument cluster
                  3- Coolant temp switch, used for cold start valve on Motronic 1.0, provides path to ground for valve (when conditions are met), which is fed 12v when cranking.
                  4- Coolant temp switch, additional input to Idle control module for cold (32degF) starting. Applicable to Motronic 1.0
                  -Dave
                  2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                  Need some help figuring out the ETM?
                  • DCColegrove
                    • 2748
                    Correct but
                    # 3 is closed below 45c for high idle only (called 45c switch)
                    WTF?
                    • kenika65
                      • Aug 2007
                      • 1336
                      Finally this has been clarified!!! wwwooo hooo thanks.
                      1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
                      1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
                      • GT BMW E30
                        • Nov 2008
                        • 2491
                        See that is what I am talking about.. Thanks dude...
                        I have noticed since it has been getting cold that the car takes longer to crank. So this looks to be the problem.
