Catylitic Converter
  • Motorsports
    • Feb 2007
    • 2882
    Catylitic Converter
    Hey guys, The catylitic converter in my car is broken up inside. I was thinking about replacing it with a highflow aftermarket cat. A friend of mine just told me to run a straight pipe. My car already has a Scorpion exhaust. Should i get a OEM cat. What do you guys think?
    • 34844
    FYI last time I checked, a new OEM cat from BMW is well over $1000. I'd be looking at aftermarket or a resonator. a straight pipe is going to make it much louder.
    • der affe
      Technical
      • Dec 2005
      • 8452
      i just put a magnaflow 2 1/4" dual in and dual out on my car last month to replace the rattling aftermarket cat. it sounds NICE!!!!!
      are you still running duals or did you go to a single.
      i always though that regular aftermarket cats were junk flow wise and when i switched the muffler out, it was confirmed!
      i had to totally re tune the car after. the sound is still pretty quiet too. you can find the mufflers for around $100 and they DO FIT in the space where the cat section was.
      you can also do it cheaper with a pair of glass packs too. it is a little buzzy though.
      i have the old section with a pair of 2 1/4 " glass packs that i would let go cheap. the only problem is the muffler shop hacks that put on the cat cut off my stock flanges. mad hatter mufflers sucks!
      i got better MPG, better acceleration, and a nice tone with out the rattle when i was done
      • daniel
        • 6703
        doesnt NY have state inspections? you won't be able to have a car without a cat there if they do. just get a high flow aftermarket cat.
        http://instagram.com/dslovn.drives
        • ejnight
          • Apr 2007
          • 3488
          http://raceskids.com/
          • der affe
            Technical
            • Dec 2005
            • 8452
            duh....flanges my BROTHA!
            bolt in the cat for inspection, swap out the muffler the reat of the time.
            your cat will never wear out, and you can run a flow clogging aftermarket for the short time you need to.
            • Motorsports
              • Feb 2007
              • 2882
              Am not too concern about state inspections. There are ways around that, Am more concern about the car running the way it should, and i dont want the car running any louder. I like the sound of it. Do you guys think that an aftermarket cat would do the same job as the original.
              • der affe
                Technical
                • Dec 2005
                • 8452
                no. if you are dead set on the cat get a high flow aftermarket one.
                the reason i did the muffler instead of straight pipes is i actually liked the way it sounded with the cat, but with a 292 deg cam, it eats up the aftermarket cat and it starts to rattle in 4-6 months.
                trust me, you will like the sound with the magnaflow muffler!
                • kamotors
                  • Nov 2007
                  • 7102
                  i have a catco high flow cat and its sounds very nice, i passed smog with flying colors.
                  7speedshop.com
                  • der affe
                    Technical
                    • Dec 2005
                    • 8452
                    part number 11378. magnaflow MUFFLER!!!
                    here is a link so you can see the dimensions
                    an aftermarket cat SHOULD clean up the exhaust gases as well as a stock one. it will not flow like one. the aftermarket cat will not stay good as long either because it has less honeycomb and platinum in it
                    • jflip2002
                      • Sep 2006
                      • 4377
                      Originally posted by blunt
                      • der affe
                        Technical
                        • Dec 2005
                        • 8452
                        you should do this too then!
                        • jflip2002
                          • Sep 2006
                          • 4377
                          • der affe
                            Technical
                            • Dec 2005
                            • 8452
                            you can just delete the code like on GM's right?
                            it sounds really good with the mufflers in place of the cat/cats
                            • Rennsport
                              • 2139
                              if you have a connections for a die grinder and welder, cut the fucker open (from the top side) break all of the shit out of it, weld it back together.
                              It will now just act as a resignater.
                              Plus Side:
                              high-flow, no rattling, appearance of a cat, free.
                              Down Side:
                              a touch louder, illegal (but you can just say that is how it was when you bought it and you didn't know about it.)
                              m106 1990 e30
                              e36 daily
                              e32 cruiser
