Originally posted by chucko
View Post
Camber adjustment question
it seems to me that the IE and the orig. BMW ones "turner" you cannot adjust-- so for the money it def. seems the Vorschlag is the way to go.
BTW, I have the turner "bmw orig." on my M3 to add even more neg. camber -- because it looks cool.... and they added alot- so to use them to try to bring the camber out of the suspension you might just end up with pos. camber then.
Originally posted by mikeedler View Postit seems to me that the IE and the orig. BMW ones "turner" you cannot adjust-- so for the money it def. seems the Vorschlag is the way to go.
thats what i figured, what if when i try to remove my camber its totally not where i want it? thats why i need the cheapest fully adjustable camber plate there is lol.
A lot of camber plates don't let you add positive camber so be sure the ones you buy will do that.'89 325is S50 Track Montser
'04 X5 Daily/Tow Vehicle
http://www.avarestoration.com
http://www.myspace.com/brendanfiddle
Click here if you want to be my zombie slave...
http://www.youtube.com/user/Fidhle007
Originally posted by Fidhle007 View PostA lot of camber plates don't let you add positive camber so be sure the ones you buy will do that.
Originally posted by joehasane30 View Postdo u mean if i put the plate on the most positive setting it has will still be the same if not more negetive camber then i already have? thats pretty stupid I.M.O. if they sell them like that.'89 325is S50 Track Montser
Originally posted by Fidhle007 View PostThat's exactly what I mean, and that's how they're sold. Must of us who are going to drop $300 on camber plates are doing it to improve handling, not to improve tire wear. If I wanted even tire wear I wouldn't drive a low car.
Joe, I called Vorschlag a couple of months ago.
Their attitude was basically "who gives a shit about tire wear, you need to corner faster", but they guy did explain that with stock replacement (ie "lowering: springs) there is just not enough room in the strut tower to make a whole lot of difference in camber.
I will have stock or nearly stock toe and camber before summer hits, I promise.
I have the spare subframe, I have the bitchin' 7 series bolts, now I need new bushings and to get to work.
Originally posted by StereoInstaller1 View PostJoe, I called Vorschlag a couple of months ago.
so basically the vorshlag wont do much positive for me?
Originally posted by joehasane30 View Postjust got one, its the camber, trust me.
From tearing appart countless E30's and putting a few back together again, it sounds like you have bent suspension components.
lowering springs will do little change to the static camber on the front of an E30.
with that said, i have a set of IE add on camber plates that i'll sell you if your interested
Originally posted by Eric View Post
From tearing apart countless E30's and putting a few back together again, it sounds like you have bent suspension components.
Originally posted by wannaBMthree View PostThats gotta be my problem. One of my rear tires has noticeable more neg camber than the other. So where do I start looking for damage??
could also be down to your subframe/rear trailing arm bushings being worn, if they havent been changed id start with them.
Originally posted by Eric View Postlowering springs will do little change to the static camber on the front of an E30.
The plates I have read about that allow adding some positive (correcting negative?) seem to say they will take out .5 degree of negative.
That does not sound like much.
Originally posted by kev.skyline View Postlook at your rear trailing arms and see if theyre bent.
could also be down to your subframe/rear trailing arm bushings being worn, if they havent been changed id start with them.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Originally posted by StereoInstaller1 View PostI keep hearing that, about the "little camber change" and then I look at the difference between my car and the wifes car...there is a BUNCH of camber to the naked eye...dunno how that works on a rack, but it sure looks like a bunch.
