OEM Paint
  • PhillyG
    • 754
    OEM Paint
    Where can I get the oem paint codes or whatever I need to get the oem paint. Need to paint my front bumper and valence.
  • Mastrcruse
    • Sep 2005
    • 5340
    front drivers side strut housing. There is a sticker that say your colors name and code...unless its not the cars original color.
    • PhillyG
      • 754
      Doh, I knew the name was there didn't remember the code was too...
      Napa would carry these products?
      • Eric Giles
        • 1068
        Most NAPA stores should carry paint for bodyshops, although not all of them have mixing machines-at least around here.
        My friend that paints recommends BASF R&M as he finds it easy to spray and since the base reduces 2 to 1, so you won't have to buy as much basecoat paint to do the job. You could also go with BASF Glasurit, but it is more expensive. We used their R&M line on my car during the repaint.
        Eric Giles
        '20 M2 CS
        '04 M3
        '11 X5 35D
        '87 325is
        '91 325i Sport
        There are few things more expensive than a cheap BMW...
        • mrsleeve
          • Mar 2005
          • 16387
          I would use PPG for all you paint supply needs, that all I have ever used.
          here is a site to get a look at all the paint codes an chips
          Huge supplier of Automotive Paint, Auto Body Supplies, Airbrush Equipment, Car Detailing Supplies, Pinstripe Paint, Spray Guns & Safety Respirators at Wholesale Prices. Our items are factory direct and we carry a wide variety of Top Quality Brands.
          Originally posted by Fusion
          William Pitt-
          • der affe
            Technical
            • Dec 2005
            • 8452
            DuPont or ppg seem to be easier for the novice painter.
            I've worked in shops that have used all 3.
            when we did a switch over to RM from ppg it seemed to take the painters longer to get is sussed out with things like flop and tinting.
            it is really up to you.
            i would however go to a automotive paint supply to get your paint instead of napa. they are better suited to match your colours and can do a custom mix if needed
            • mrsleeve
              • Mar 2005
              • 16387
              Yes I 100% concur on that and yeah Dupont is good stuff too, I just prefer PPG as thats all I have ever used.
              William Pitt-
              • mikeedler
                • 6707
                Glasurit is what BMW uses. use what ever is cheap if your doing a DIY in a garage thing, the quality you see won't be there from hi-end products in a no professional environment.
                • PhillyG
                  • 754
                  Yeah I'm just gunna get whatevers cheaper. Not going for super quality. The cars more or less a beater. Just wanna keep it all one color.
