Any interest on an ITB group buy?
  • z31maniac
    • 17566
    Extrudabody Items:
    6 cylinder Triple Linkage Kit. throttle Control Section $125.00$125.00
    Remove 16-ITB-KIT-40/45mm or Triple DCOE/IDF Web Bolt Patterns
    (45/50mm Taper Bore) Weber Replacements section $1,249.00$1,249.00
    Remove 1M0-44M-044 BMW M20 Triple DCOE Manifold Manifold only Section $365.00$365.00
    Remove 1FR-Custom-Drilling-4&6 Fuel Delivery section $35.00$35.00
    After atomic posted these guys website up in the intake manifold discussion, I've chatted with Kevin there through email.
    As you can see, normally the M20 setup comes in at a tick under $1800. Still working out the details but it appears that with 6 sales he would take 20% off, so around $1420. Obviously you still need EMS and a plenum (they do have a template for the ITB's to build your own).
    Consider the Dbilas setup (with the current exchange rate) is checking in at just under $3k. Although I'm not sure what all the Dbilas comes with so I won't make any comments there.
    No hurry on this, just thought I'd send out a feeler.
    www.gutenparts.com
  • e30s52
    • Oct 2007
    • 5235
    What about for 24v?
    www.gutenparts.com
    • vivalegreg
      • Apr 2006
      • 1313
      that looks really good..
      e30s r kool
      • E-Thirty
        • 1331
        What about running it without a plenum?
        Do you feel like something is trying to penetrate your butthole?
        • Edev
          • 3731
          what benefits would you see? im not sure what an ITB does to our cars.
          M Coupe
          • z31maniac
            • 17566
            Originally posted by e30s52
            What about for 24v?
            They do have a 24v kit. He said for the purposes of the GB they all needed to be the same. But I'll double check and see if its a possibility.
            You could, the TB's have a nipple next to the fuel injector opening so you can connect all 6 TB's to a vacuum log and take a MAP reading from that. But I thought I remembered Ely (rs4pro3) having problems with that on his homemade setup. If you wanted to run an Alpha-N setup you could probably get away with it.
            www.gutenparts.com
            • Dave
              E30 RAT
              • 11675
              The 24v setup is pretty nice as well. I know a guy who has them for his turbo M52 he is building in his e30.
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • e30this
                • 3580
                What about for 24v?
                Your thinking like me.
                Machine work might have to hold off for a while..lol
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  You will need at least runners.
                  john@m20guru.com
                  Links:
                  • Need4Speed
                    • Jul 2008
                    • 95
                    I have heard some not so good things about Extrudabody wear wise.
                    • z31maniac
                      • 17566
                      I don't have any personal experience with them either, so I can't comment on that.
                      However, if you don't have evidence to back up your claims, don't start talking shit about a vendor based on hear say.
                      www.gutenparts.com
                      • dude8383
                        • Jan 2005
                        • 10387
                        What about for 24v?
                        now we're talking.
                        how much does the kit cost anyway?
                        • Huff
                          • 2488
                          Man.. At that price point I'm VERY interested.
                          • e30this
                            • 3580
                            So does the price go down if more people get invloved?
                            Even if it is 24V and M20??
                            • tecks2k
                              • 221
                              Those are freaking beautiful! WOW!
