Oil Pan Help
  • shmutzigE30
    • 1680
    Oil Pan Help
    So I'm trying to replace my oil pan myself and from looking at it it looks like I have to take my transmission cover off??? I really don't know right now but someone if you have a link to something to help or any advice it would be greatly appreciated as I don't wanna pay $300 for a tow truck and soonekne else to repair. Thanks
    AW 89' 325i Vert - SOLD
  • chrisesteschiro
    • 361
    first step is try a search....unbolt your engine mounts and jack the engine up, remove oil pan, replace.............
    • AndrewBird
      The Mad Scientist
      • 11897
      There is a plate/reinforcement kind of thing at the back of the oil pan, but it is only held on by a few bolts and I'm not even sure if you have to remove it.
      • Nic01101011
        • Jan 2008
        • 1549
        there are either 4 or 6 torx bolts holding it on, but you can used the closed end of a normal wrench(9mm I think? experiment) to get them off
        • mintscorpion
          • Jan 2009
          • 91
          I just searched for "how to remove m20 oil pan" on google and this is the first result that comes up:
          You should really try to search before you ask questions. In the words of John Lennon, "It's easy if you try...".
          -Matt
          1986 BMW 325
          • shmutzigE30
            • 1680
            right... thanks a lot ;)
            • smcdermott326
              • Jan 2008
              • 84
              also: http://www.bmwtechinfo.com/repair/main/561en/index.htm
              Section 11 13 000
              • Dragowl
                • 287
                its still a pain in the rear to do...but pretty straight forward...
                • Jand3rson
                  • 37587
                  People really need to learn how to use Google. Here's an article, by me, step-by-step on how to do it.
