m20 timing 180 deg. out?
  • Mike
    • 932
    If you have your block set at TDC, using the lower timing cover notch, and you have your cam gear set at its mark, and your balancer lines up with its notch, should cylinder #1, or cylinder #6 be on overlap?
    Supatek -noun - your basic know it all
  • backtrail69
    • Jul 2005
    • 4471
    Line up the head and the block at the TDC marks.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • whodwho
      • Jun 2008
      • 1547
      Not on overlap but lobes down and rockers loose.
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • Mike
        • 932
        Ignition rotor at TDC should be at 11 oclock, or 5 oclock?
        • whodwho
          • Jun 2008
          • 1547
          Don't go by the rotor, there will be a notch on the cam sprocket and a line on the head that line up.
          • Mike
            • 932
            I understand, but I searched, and found some topic that basically the crank rotates 2:1 per cam rotation., and that you can in affect, get the spark to occur on the exhaust stroke....get it?
            • whodwho
              • Jun 2008
              • 1547
              It does turn twice the cam but with the crank is on it's mark Cyl #1 is on TDC and with the cam on its mark the dist rotor can only point to Cyl #1 on it's compression stroke.
              • Tree18is
                • Mar 2004
                • 2703
                make sure!!!!!!!!!!!!! you tighten the timing belt adjuster screw! and crank the engine over twice by hand.. and make sure you belt doenst stretch or move the tensioner.. mine did..
                now I need a head.
                k cool bye.
                • whodwho
                  • Jun 2008
                  • 1547
                  To clearify your Q, didn't see you were asking on 1 or 6, this would be for Cyl #1
                  • whodwho
                    • Jun 2008
                    • 1547
                    now I need a head.
                    k cool bye.
                    Actually you do want to leave the tensioner loose so that the spring of the tensioner puts the proper tension on the belt as you turn it the two revs(in the correct rotation never backwards) - recheck your marks and tighten the tensioner.
                      • 34839
                      TDC on #1 and #6 are the same. 180/360 doesn't matter, all that matters is that the marks on the cam and crank match.
                        • 34839
                        no, it doesn't matter. see my post.
