Interest: 5 bolt hubs
  • SamE30e
    • Sep 2007
    • 4319
    Hey guys,
    I was just wondering how many people would be interested in 5 bolt hubs that fit on the 325 that would use e36 rotors. And caliper adapters for e36 calipers.
    Basically a 5 bolt swap without swapping trailing arms or strut tubes.
    Sam
    1985 325e 2.8 Turbo VEMS
  • fretburnr
    • Jan 2005
    • 1496
    hell of an idea.
    Jay
    • SamE30e
      • Sep 2007
      • 4319
      Well, it's do able, just need to see if anyone would be interested, or if they would rather just get the 318ti and e30 m3 parts.
      • FredK
        • 14762
        How much.
        That's what everything boils down to, really.
        Ti rear parts cost very little, and E36 front parts don't cost a whole lot either. If there were a cost effective way of getting the correct geometry up front with custom E36 front strut housings, I think you'd have a real chance at selling something. The beauty of the E36 strut housing is that the tie rod and control arms bolt to a kingpin, so the strut housing itself isn't a terribly complicated thing to manufacture.
        • SamE30e
          • Sep 2007
          • 4319
          I was thinking of just basically 5x100 (or whatever e36 pattern is) version of E30 hubs that accept a E36 rotor and a caliper adapter. I have no idea on price. I assume a full 5 bolt conversion is somewhere in the 500$ range + misc parts, so it would be somewhere around there and would retain the stock E30 suspension geometry.
          • Jand3rson
            • 37587
            I think it's a great idea. But E36 wheels and bolt patterns are 5x120. You want to try to make a 5 lug conversion kit, and you don't even know what the bolt pattern is?
            • einstein57
              • Jun 2007
              • 10780
              how about some 5x120 hubs and some re drilled e30 brembo blanks. I'm down if you can do it for lets say 2-250.
              www.gecoils.com
              • atomic
                • Jun 2007
                • 5691
                might want to research some more before getting all antsy...
                good idea if you can make it work!
                :mrgreen:
                • SamE30e
                  • Sep 2007
                  • 4319
                  Thats a small detail. It's a simple question, I haven't looked into it too deeply, just gauging interest.
                  You guys are getting upset over small things.
                  • Jand3rson
                    • 37587
                    Ummmm, I would probably venture to say...
                    IT'S THE LARGEST FUCKING DETAIL INVOLVED IN THE SWAP.
                    • SamE30e
                      • Sep 2007
                      • 4319
                      The big details are.
                      E30 hubs..
                      E36 bolt pattern...
                      Have I drawn or designed the things yet!? I'm pretty sure that if I was going to design them I might double check the bolt pattern. It was off the top of my head.
                      Like I said, it's simply gauging interest. It wouldn't have made a difference if I stated the bolt pattern or not.
                      • e30s52
                        • Oct 2007
                        • 5235
                        Would this even be safe?
                        www.gutenparts.com
                        • Jand3rson
                          • 37587
                          Based on what I've read so far, no.
                          • FredK
                            • 14762
                            Well, the hub is a precision machined part. I'm not sure it'd be worth your while to machine 5 - 10 sets for ca$hlimited members.
                            • SamE30e
                              • Sep 2007
                              • 4319
                              Why wouldn't it?
                              They wouldn't be re drilled stock hubs, they'd be CNC'd from scratch.
