Interest: 5 bolt hubs
  • Mtriple
    • 3139
    #46
    no thanks...
    Originally posted by Simon S
    • reelizmpro
      • 9559
      #47
      What's so wrong with running the E36 stuff? Seen it on Matt's car and it looked fine. He's happy with them.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • Jand3rson
        • 37587
        #48
        Originally posted by DCColegrove
        Ya know...
        This is way more complex and costly than a lot of people seem to think it is.
        If you want to toss out ABS, the Integrity of the knuckle, and a whole host of other things.... Okay fine.
        Thank you.
        • craz azn
          • 752
          #49
          So whats the advantage of this versus the e36 parts swap? I don't get where this is going...
          I'd rather stick to the disadvantageous e36 swap rather than some hubs designed by a uncreditible source.
          Rippin' Proper | Youtube | Vimeo |
          • blunttech
            • 12850
            #50
            i wouldnt mind going in on this as a joint venture. i can supply the rears. here is my car ive been running for over a year and several track days. spacers are 3/4" furniture grade plywood with 3 coats of marine varnish. holding up great so far. let me know if you want to handle the fronts and i could whip out the backs
            fuck the haters. mods can be done economically if well thought out
            sales@blunttech.com
            www.blunttech.com
            Like us on Facebook
            • Rigmaster
              • 3464
              #51
              Shut the fuck out!!!
              Every E30 pantus de baggus worth his bong knows that pic is the big brake upgrade you did to that POS orange 2002 you and jonny bondo'ed up one weekend fueled by Mountain Dew and Moon Pies.
              • blunttech
                • 12850
                #52
                the point is i have the skill to pull this off. and the woodworking tools so you shut the fuck out
                sales@blunttech.com
                www.blunttech.com
                Like us on Facebook
                • atomic
                  • Jun 2007
                  • 5691
                  #53
                  Mmmmmmm.... Moon Pies
                  • Mtriple
                    • 3139
                    #54
                    Originally posted by atomic
                    mmmmmmm.... Moon pies
                    +1
                    • Rigmaster
                      • 3464
                      #55
                      Originally posted by Mtriple
                      +1
                      I think you guys meant to post this in the "lets legalize pot" thread going on now in OT.......
                      • chris4891
                        • 51
                        #56
                        i came in a little late, but i just wanted to give my take on machining new hubs. i dont know your background or experience, so im writing this as if you were an average joe (joe the plumber maybe?)
                        it wont be that difficult to design (draw) a new hub that makes all the parts fit together with the correct geometry. 2-3 hours (at most) in pro/e or solidworks, whatever youre using. thats the easy part.
                        but if you want to provide a product that is as sound and reliable as the oem item, you've got a bit of legwork to do. there are two routes, endless trial and error testing or the current tool of choice -> FEA. either way, you need to know or be able to approximate the forces present at that location. then some stress analysis. then its a bit of an iterative process.. selecting materials and processing (heat treatment, etc) that will give you a part thats strong enough.
                        the hub, as with many rotating parts, will see a fully reversed loading. its also a critical component. dont want any wheels falling off. so then you need to do a fatigue study.. how many cycles can it withstand, etc? after that you should be good to go, more or less.
                        dont get me wrong, this project is entirely doable, in fact i plan on doing these types of projects once i have enough $$ to get my own lathe and milling machine. i just want you to be aware of what you might be getting yourself into. as ive hinted, theres a lot of legwork thats done behind the scenes on parts like these. for reference, i work with a group that does structural analysis, and we charge $100/hr for services similar to what you will need to do in order to properly design this part.
                        here are a couple things you should figure out (and if you figure out #2/3 let me know ;)):
                        -approximate forces/moments on the hub
                        -oem hub material
                        -oem hub hardness (lets you approximate the heat treatment and resulting strength of oem part)
                        • Adrian_Visser
                          • Jun 2006
                          • 2823
                          #57
                          are you fucking for real you have plywood holding your brake calipers on? I'll admit i didnt read the whole thread so i dunno what was said before but how the hell can plywood handle the shear load of your calipers when your braking? that just seems a little hokey to me
                          '89 Alpine S52 with goodies
                          • blunttech
                            • 12850
                            #58
                            its not regular plywood dude. its furniture grade and i have it sealed with marine poly. its has held up with no issues for over a year. i suppose youre another engineer who is going to tell me its not safe. hahahahah i will outbrake you at the last minute and swoop down to overtake you in the corner.
                            sales@blunttech.com
                            www.blunttech.com
                            Like us on Facebook
                            • Massive Lee
                              • Sep 2006
                              • 6785
                              #59
                              massivebrakes.com
                              • xLibelle
                                • Aug 2004
                                • 2673
                                #60
                                I'd pay no more than $250 for the set of hubs alone. And if they were available for that, I would almost 100% be in, BUT I would want an money back gurantee if I found that upon installation, that they did not fit my level of quality.
