E30 vs E36 radiator?
  • z31maniac
    • 17566
    I plan on buying a new radiator for the swap as the old one is pretty crudded out.
    They seem to be about the same price, any preference for one over the other?
    www.gutenparts.com
  • z31maniac
    • 17566
    No input at all?
    www.gutenparts.com
    • Jaygo333
      • Jan 2008
      • 334
      bump.
      • jmarch
        • Oct 2004
        • 163
        If you have an M20, why would you want to try another radiator? The E30 radiator is more than up to the task of cooling an M20.
        1995 Porsche 993 6 speed
        2001 BMW M3 6 speed - DD
        2001 BMW 530iA Sport - Hers
        2005 KTM 450EXC 6 speed
        Gone:
        1988 BMW M3 2.5 EVOIII Clone
        1988 BMW 325is x2
        1985 BMW M635CSI 286hp
        2001 KTM 400MXC
        • ECVCHAMP
          • Jan 2009
          • 37
          I went with a all aluminum for an e30 and I am verry happy with it
          • z31maniac
            • 17566
            Did you read my post? The part about the radiator that's in there needs to be replaced?
            Hence asking if there is any reason to go with an E36 over an E30, vice versa.
            www.gutenparts.com
              • 34844
              aren't E36 radiators notorious for cracking at the plastic necks where the hoses attach?
              I know E30 radiators use plastic too but it's almost unheard of. Thus the reason E36 owners switch to all aluminum.
              • ECVCHAMP
                • Jan 2009
                • 37
                My stock e30 rad. cracked at the upper neck but, thats with 200k miles on it and when I pulled it out I held it up to the light and about 90% of it was pluged up with bugs and junk
                • jmarch
                  • Oct 2004
                  • 163
                  Didn't you read mine? Why consider a swap of a standard part which does it's job more than adequately? Do you have too much time on your hands?
                  Gone:
                  1988 BMW 325is x2
                  2001 KTM 400MXC
                  • z31maniac
                    • 17566
                    ^Cause I'm going 24v, hence the question.
                    That's what I wanted to know, thank you sir. I'm still not completely up on all the 24v/E36 type stuff since I previously had been planning a stroker M20.
                    www.gutenparts.com
                    • mck
                      • Jan 2007
                      • 238
                      Most car radiators are usually designed bigger than they need to be, specially with BMW. to be honest I think the best radiator is the one from the late 318i, the one with the built in overflow tank. specially if your doing a 24v swap it will save room in the engine bay.
                      '89' E30 with Euro S50B30
                      • Mitchel
                        • Jan 2009
                        • 35
                        Go all aluminum.
                        1998 Hellrot M3, perpetually on jackstands
                        1985 325e
