Car doesn't fire up, turns over without clutch depressed, randomly...help..
  • Moto-Mucci
    • 2058
    Every once in a while my car won't fire up. Today, it was running, then while I was trying to pull out of a parking spot, it shut off. It felt like a stall, but I had the clutch in at the time it did it.
    When I went to turn it back on it wouldnt start, it would just wind out the starter. I could even try to start it when I didn't have the clutch pedal in. ..that scares me.
    I went out to eat and came back and it fired up like usuall.
    Any idea what it could be? It sounds like it would have something to do with the clutch cable...but i dont understand why it would be random. I'm hoping this is a familiar problem.
  • boom-monkey
    • 1104
    Are we talkin' e30? There is no start safety switch on the clutch so they will start with the clutch engaged. Also they don't have clutch cables.
    Anyways, does the starter engage the motor or just wind out like you described? If I had to throw out a random guess judging by symptoms I would say ignition problem. Check the distributor cap?
    • fretburnr
      • Jan 2005
      • 1496
      There is no clutch cable on an e30 (hydraulic clutch), and also no clutch interlock switch; you can start any of them without hitting the pedal.
      Sometimes if a car stalls shortly after a cold start, it can flood a bit, and it can take a little time or more cranking for the excess fuel to dissapate. Next time try cracking open the throttle a bit on the restart to allow more air to enter.
      Jay
      • Moto-Mucci
        • 2058
        Ahh good to know, that would explain why I couldnt see any active cables with the gf was depressing the clutch. I'm still new to these cars.
        I'll have to check the distributer. It bogs if I try driving it before it warms up when it's cold out too. Could both these problems be a faulty cold start inj.? Do these cars have cold start injectors...?
        • mikekristine325ic
          • Nov 2008
          • 338
          Check the Ohms on your coil. My Vert was doing this and found out that it was my coil heating up and going out. As soon as it cooled down, my car would start and run fine. MSD Blaster 2 Coil is an awesome replacement.
          sigpic...
          1991 325is- Current Project w/ 150k on the clock
          1990 325ic- SOLD w/425k on the clock and still ran!
          1985 528e- SOLD
          1972 2002tii-Should have never sold it!
          • AndrewBird
            The Mad Scientist
            • 11898
            Is the starter spinning but not the motor? If so, sounds like the drive on the starter is bad and the starter isn't engaging the flywheel.
            • Moto-Mucci
              • 2058
              How can you tell if only one or both are spinning? Sounds like just the starter, there's no attempt at firing up.
              • SpecM
                • Oct 2005
                • 4531
                is the engine turning over or not?
                1989 cirrisblau-metallic 325i
                • PhillyG
                  • 754
                  Well does it sound like a little motor spinning up or a engine trying to fire?
                  • Moto-Mucci
                    • 2058
                    like I said, there's no attempt at firing, it just sounds like the starter.
                    • Adrian_Visser
                      • Jun 2006
                      • 2823
                      ughh that's not very helpful, if the starter isn't engaging it will just whirr away making a much higher pitch sound than when cranking the engine because it will spin way faster as there is no load on it, if it sounds the same as normal starting then it is engaging properly.
                      i had a similar problem on my old e28 once. i traced it to the ignition, repalced the coil and it worked again, for a while then it happened again. It turned out the connection at the main relay was intermittant... fixed that no problems ever again
                      if i remember correctly the main relay powers the reference signal sensor or tdc sensor (maybe both i can't remember), anyways the ecu uses the signal for ignition timing so check the connections at the relay and sensors too
                      '89 Alpine S52 with goodies
                      • Moto-Mucci
                        • 2058
                        Ahh ok, then it is engaging. Sounds normal, just doesn't fire.
                        Good info though, thanks.
                          • 34844
                          is your car a 325e? if it's not, then it doesn't have a cold start injector.
                          are you getting spark? Have you tested the crank sensor? does the fuel pump turn on?
                          • PhillyG
                            • 754
                            If thats his car in the sig than its most likely a b25. I'm thinking ignition.
                              • 34844
                              I have sigs turned off ;)
