ugh...sucks soreee
    ugh...sucks soreee
    was driving my little e30 around today...
    smelled some gas.
    the gas line running from the gas tank too the fuel filter has cracks all on it and its just spitting gas all over the place.
    now i had to get my car towed 40 miles home to my garage...and i smell like gas...and i get to go to class reaking.
    anyone know how to get that line off the gas tank without dropping the tank?
    i had AAA though...which turned out to pay for it all...anyone know how to get that line...i dont have the car with me yet so i cant take pics or anything
      haynes/bentley? look on scribd.com to see if its online there.
      1991 325iC - Mauritsblau sumthin metallic blue. DEAD
      1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
      1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
      1991 325iC - Calypsorot Metallic
      1994 540i - Granitsilber
      Originally posted by scabzzzz
      I've had blunts cock in my mouth, but I'm not gay.
        on mine is was 2 flex lines comming out of the fuel filter. one from the line forward and one from the filter to a hardline. IIRC it is 8mm fuel line (flex)
          what is soreee?
          http://instagram.com/dslovn.drives
            Ha. I made a thread about this earlier today in the general section. If there's a screw-type clamp on that line, there's no getting to it without dropping the tank. I unbolted the 4 corners of the tank (13mm), then had to unbolt the center exhaust shielding (2 10mm's, 6 13mm's) and use a swivel to get to the center tank bolt. Then there was just enough room to loosen the clamp, and pull that fucking line off. That is.. after I removed the bracket that holds the fuel filter in place (3 10mm's.)
            Have fun!
              Have fun!
              that is what i did.
              thanks man!
                Am I missing something? Did you guys really pull the tank to change the fuel filter and lines? When I did it, I just cut new sections (totaling about 18in) of fuel injection hose, placed them on the hard lines and mounted a new filter. What is different about your cars?
                Originally posted by chileelky
                amaze about the enthusiasm e30 generate
                  The clamp on the line going from the tank to the filter cannot be accessed without dropping the tank slightly. Don't know if there's any difference or not, but this issue was on my '91 318is.
                    yea...i found it easy to take out the back seat and the sound proofing/insulation panels and you have access to the lines. i found that out AFTER i dropped the tank a bit though.
                      I tried that too, but still could not access that damn clamp. Just out of reach from the hole on the driver's side.
                        Originally posted by daniel View Post
                        what is soreee?
                        still looking for an answer. thanks.
                          It means SORRY
