speedometer stoped working.
  • etta325
    • 985
    after I reset the miles after getting gas, the odometer stopped working. i first thought it was just the miles that you can reset, the trip miles or whatever, but then I started watching the actual miles and it was not working either. any suggestions as to what might be wrong and what I can do to fix it?
    Check out my stuff for salehttp://www.r3vlimited.com/board/show...=1#post1600997
    anything you need I can find just shoot a PM
  • atomic
    • Jun 2007
    • 5691
    So your odometer doesn't work after a reset when getting gas or the speedometer?
    There is a difference you know?
    • TDE30
      • 7042
      I don't know what the fuck you mean, but I'm pretty sure you are talking about the odometer. Best of luck with that, it's probably the smallest gear in the odometer than finally broke.
      Atomic, that's a bitchin' manatee in your avatar.
      - Trey
      E90 325i/6 (ZSP, ZPP, ZCW)
      E36 325i sedan
      E30 325i sedan
      Volvo 945T
      • etta325
        • 985
        ya. i messed up. changed it. so the odometer is not working after reseting it after getting gas.
        • atomic
          • Jun 2007
          • 5691
          Then you broke your plastic gears.
          :up:
          • etta325
            • 985
            ya so what do I do to fix it?
            • TDE30
              • 7042
              Search.
              If you are unable to do that, buy a Bentley manual.
              If you are unable to do that, remove the cluster, then remove the odometer, figure out which gears are broken (likely the smallest gear in that unit,) and replace that gear or gears. Inspect the cluster and odometer itself as it may only be a broken solder.
              - Trey
              E36 325i sedan
              E30 325i sedan
              Volvo 945T
                • 34844
                are you guys resetting the odometer when the car is moving?
                • atomic
                  • Jun 2007
                  • 5691
                  Ebay will be your best bet for sets of gears, BUT you need to know what sizes you need depending on which cluster you have (there are several options and only one size of each gear will work)...
                  And search or dig in it. It is quite simple to fix once you figure which gears you need...
                  :up:
                  • atomic
                    • Jun 2007
                    • 5691
                    Should mention that as well, if the car is in motion when you push the reset button you will likely break one or more of the plastic gears.
                    :idea:
                    • etta325
                      • 985
                      :up:
                      these are the answers I was looking for. thanks
                      :idea:
                      shit balls. thats what happened then. i was rolling when i reset it. my bad. never seemed like an issue in the past. ill make sure to figure that shit out.
                      • atomic
                        • Jun 2007
                        • 5691
                        There is a guy in Spain that is great to deal with when getting them on Ebay, around $15.00 shipped for a set. If you get them at the dealer expect around $25.00 each...
                        • Edev
                          • 3731
                          Do you know of this guy? Mine broke a while ago and want to fix it.
                          M Coupe
                            • 34844
                            yeah, don't do that. 212k on my odometer, I hope it never breaks. :)
                            • daniel
                              • 6703
                              odometergears.com
                              http://instagram.com/dslovn.drives
