Diff?
  • weedcookie
    • Oct 2007
    • 101
    Diff?
    I got a question,
    i have a 89 325, and a broken diff. i think its a 2.93...pretty sure...
    a friend of mine has a 3.91 from 88-89 325 , what difference will it make if i put the 3.91 in my 89 325?
    :hitler:
  • gearheadE30
    • Jun 2007
    • 3734
    Look at the tag on the back of it. It is not a 2.93 if it is an '89. If it was an 88 or something, I could see that. 2.93s came on the etas, not the i motor.
    Is your car auto or stick? Sticks had a 3.73 and autos a 4.10 with the i motor, which you have if its actually an '89. The 3.91 will be either a tad higher or lower than what you had in there.
    Project M42 Turbo
    • weedcookie
      • Oct 2007
      • 101
      yeah i think thast the way i bought the car wiht the eta diff. ... 2.9 smthign on the tag and im gona use the 3.9 from ix
      my cars manual
      :hitler:
      • Collin
        • 1736
        my cars manual
        Then you will go from a ratio of 2.93:1 to a ratio of 3.91:1 at the back end. You'll start moving faster, but it will lower your top speed.
        I really really want a 4.10.
        The Keystone Killers
        With 73k+ post, you'd think he'd have learned a little about life.
        • SynSyx
          • Apr 2008
          • 542
          so my '89 325i (auto cabrio) has a 4.10?
          also, i too am a member of the 1/2 db 1/2 pb divison of the alpine command haha
          BavAuto ~ Bilstein ~ BBS ~ Scorpion ~ MarkD ~ Prolumen
          Have you hugged a corner today?
          '89 335iC (M30) - summer
          '17 Mazda3 - winter
          • Collin
            • 1736
            For those of us too lazy to finish the job
              • 34839
              not really. Most E30s don't have enough power to be gear-limited at their top speeds, they are simply limited by the brick shape surface & lack of power.
              • miles318
                • 76
                If you switch to the 3.91 you'l probably have to shift a crapload. Also make sure the diff you put in is the same case size(there are large medium and small) i don't know for sure, but the one you have is probably medium
                • HiTheNameIsBJ
                  • Jan 2009
                  • 1116
                  Go to bimmerworld.com and click on the tech section, there is a exel file where you can input your gear ratios and it will tell you your speed in 500rpm increments.
                  • 808BMW
                    • 2910
                    3 sizes? I know 318's came with small case diffs and 325's came with large case, where is the third?
                    • Holland
                      • Nov 2008
                      • 7176
                      Question! What fluid should I use in a LSD rear end? I'm switching to an LSD so I'm wondering what my options are.
                      Originally posted by DEV0 E30
                      • decay
                        • 5637
                        changed from a 3.73S to a 3.91V (iX diff) in my first e30. top speed didn't change- as nando said it was drag-limited, so i was just turning more RPM and probably got there slightly quicker. didn't really notice a difference in freeway gas mileage either.
                        i personally thought it was a great mod, and if i had another m20-powered e30, i'd do it again, only with a markD chip to complement it- that'd put the new redline at about the same speed in each gear (edit: same speed as my old 3.73, not your eta diff).
                        past:
                        1989 325is (learner shitbox)
                        1986 325e (turbo dorito)
                        1991 318ic (5-lug ITB)
                        1985 323i baur
                        current:
                        • willybustaE30
                          • Apr 2006
                          • 143
                          i use redline heavy shock-proof 75-90 with a friction modifier for the clutches. i went from a 2.73-2.79? (cant remember, it's e-car w/genuine dinan chip)but i went to a 4.10. it will climb a brick wall-lol! i can get 4th gear scratch on a good day. it really woke the car up, but still is slow compared to my volkswagen bus.
                          • Julien
                            • 7471
                            you must have some really shitty tires
                            Build Threads:
                            • willybustaE30
                              • Apr 2006
                              • 143
                              gee thanks,
