VIN Decoder LSD
  • e30sh
    • Apr 2015
    • 618
    VIN Decoder LSD
    Found a junked non iS e30 with no wheels sitting in the mud. Cant really get under it to check the tag. I've tried 5 or so VIN decoders. None tell if the car came with a posi. Am I missing one that will give that info.
    Thanks
  • roguetoaster
    Biggus Tippus
    • 7830
    Every decoder I've seen shows a locking differential option if the car has it, so I'd say it does not have one if not displaying. Granted one could have been swapped in over the years.
    • e30sh
      • Apr 2015
      • 618
      One does say dynamic stability control. Is that code for LSD?
      • fastestbox
        • Jul 2018
        • 124
        What's the VIN?
        91 318iS - aluminum M52B28 + ZF320 + 3.15 Torsen
        • Motheye99
          • May 2018
          • 853
          look for a 25%
          thats the LSD
          91' 318is 90' 325is
          Originally posted by Sonny
          Buy the E30s, they ain't gonna last long
          E30 can make you, E30 can break you
          "He who controls the Nova's, controls the Boomers"
          • lukeADE335i
            • Apr 2013
            • 1389
            Could also have been swapped out too even if it showed up as having a LSD when it was new! Only real way to tell is to find a way to lift the car and check the tag on the diff or take the rear cover off and have a look.
            My e30: OEM+ with M30B35
            • e30strokr
              • 211
              take the cover off? why not turn the driveshaft one full turn and see how many times the wheel/shaft part turns...
              • lukeADE335i
                • Apr 2013
                • 1389
                You can lift the rear end up, turn the driveshaft and see if both wheels turn in the same direction - if they do then it's likely an LSD. Thing is, diffs that are on their way out can sometimes lock up and behave the same way - I've had this before when at pick a part, got all excited just to get the diff home and realise that it's just a dying diff, not an LSD.
