Question. Small case 4.10 lsd fits on 325 is?
  • Groove_D
    • 131
    I'm looking at buying a 4.10 small case lsd diff. Would it fit on my 325 is? Is it a straight swap or do i need to change the flanges and the rear diff cover?
    How much do they usually go for?
    Thanks in advance guys.
  • 02stu
    • Jan 2005
    • 872
    It'll fit, but it won't last long. I had the same idea on my last e30 and sheared the input shaft to the diff.
    • mattdk318i
      • Jun 2006
      • 3953
      change the flanges, ive been using a 4.10 small case on my M50 cab for about 2 years. And it turns 17''s over daily.
      • Groove_D
        • 131
        I have a stock m20 with a 93 mark d chip. You still think it will tear small diff?
        By changing the flanges, you mean swap my existing 325 flanges into the 4.10 diff?
        • mattdk318i
          • Jun 2006
          • 3953
          no, you need the 318 flanges to reach the 325 axels
          • Groove_D
            • 131
            The guy sells it locally for $200 CDN. So you you think overall i should stay away from the small case diff?
            • mattdk318i
              • Jun 2006
              • 3953
              if you can help it, But if you already own one like i did. Throw it in there. It works fine
              • Groove_D
                • 131
                I haven't bought it yet, thinking about. Was the mod worth it?
                • Liam
                  • 753
                  It will fit but it really is not the best choice for an M20 powered car.
                  I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
                  • Julien
                    • 7472
                    *ahem*bullshit
                    maybe this is a on a 5 lug car? on a normal e30 you they are both plug and play
                    Build Threads:
                    • Holland
                      • Nov 2008
                      • 7212
                      Lol, if you can go from small case to medium case with no problem then why would it be a problem to go from medium to small?
                      Originally posted by DEV0 E30
                      • xwill112x
                        • Jan 2009
                        • 4236
                        mattdk, your wrong ;)
                        anything e30, will work for another e30.
                        • Collin
                          • 1736
                          More distance between pieces that should connect easily.
                          The Keystone Killers
                          With 73k+ post, you'd think he'd have learned a little about life.
                          • Julien
                            • 7472
                            axle shafts have a slip joint that allows enough play to fit either diff
                            Build Threads:
                            • FredK
                              • 14764
                              Hm. I didn't realize there's THAT much play in the axles. Why would BMW offer two different diff output flange widths if it didn't make a difference?
