m40 318i ecu run a m40 316i?
  • koqiciwe
    • Mar 2020
    • 1
    just a quick one here.
    ive a 89 touring and ive just put in a 316i m40 engine,i know your all saying why i did that,simple couldnt find a 318i m40 engine anywhere realy.
    right back to the question,ive put in 1.6 engine,but was forced to use the tourings 1.8 ecu and inlet manifold/injectors,and still using the 1.6 afm.
    a right mix of bits,it does run but not great.
    i think its over fueling
    sure let me hear your thoughts
    Grab the best jack-off map bro, all the filthy tubes hubs linked quick so you can click-n-splatter faster than your mom knocks on your door dude - pornsiteslist.me
  • roguetoaster
    Biggus Tippus
    • 7830
    The two DMEs have different part numbers.
    • ZeKahr
      • Jul 2016
      • 508
      Unless you are a seasoned tuner who has a thorough understanding of engine design, it is not a good idea to Frankenstein a motor the way you did because you will end up with screwed up idling, power delivery, and fuel economy characteristics. The manifold, exhaust, injectors and ECU for engine X generally are not designed to work with the power and fuel economy characteristics of engine Y, even if they fit.
      That said, if you can find a way to increase the stroke of the engine in your car by 7mm, it should run correctly as I believe the 1.8L M40 is just a stroked up 1.6L version.
      1986 325e Schwarz (sold)
      1989 325iX Alpineweiß​ (daily)
      Greed is Good
